- Mar 7, 2025
- Westchester, NY
- 25 AT, 23 Subaru Ascent
- 8W0TRV52
Have been looking at this forum for a while and finally joined! Planning on putting my deposit down this afternoon, but still trying to figure out some things about charging. It’s my first EV, so I need to set up a home charger. I have 100 amp service, and was considering putting in a 50 amp Plug, or possibly a 30 amp Plug to use with my mobile charging cable. I think I’d probably be ok with 50 amp, charging at night, but it might be a bit tight with only 100amps.
Options: I could put in the 50 amp plug and if it proves too much, I could simply plug in a charger (Chargepoint Flex?) and limit the amperage to something lower. Or I could straight away install a hardwired charger with the same option (turning the amperage up or down.)
Question: I know the Lucid typically is set to charge through the car’s interface. Can someone tell me about their experience charging their Lucid using a Chargepoint or similar charger? Is it literally just plug it into the Chargepoint and schedule through the Chargepoint interface? Any problems? Issues?
Another advantage of the Chargepoint is that it would allow me to participate in a NY program for discounts on energy (SmartCharge NY). Lucid is (by itself) not compatible with the program. I’d need a charger to “play nice” and participate.
Any thoughts or tips are much appreciated. Thanks!
