New Gravity owner - small issues and hoping for answers
I was curious because I occasionally use Audible and am also using the iOS 27 beta on my iPhone (17 Pro Max) so I walked down to my car and tried it, I was able to play and hear a book whether I started it from the app on the screen in CarPlay or directly on the phone.
It’s very strange. I have an iPhone 17 Pro so should be basically identical to yours. I may try repairing the phone with the car and see if that helps. Might also try another book.
For problem #3, before you hit restore to move the steering wheel, try putting it in drive. I don't think it adjusts the wheel until you are literally ready to drive.
No SXM antenna, so no receiver. Streaming only, IF you can get consistent internet from the car's AT&T dongle. I can't in my area. Frequently cuts in and out. Super annoying.
Thankfully the car has Android Auto now, which gets internet from the phone (far better T-Mobile signal, at least for me). So I play SXM (and Pandora, and Spotify) via AA instead. Still some dead zones on long road trips but much better near home, at least.
When I can't get a signal at all, I use Musicolet via AA to play songs downloaded on my phone.
If you have bad AT&T service but good cell service otherwise, keep in mind you can also tether / personal hotspot.
It does it when you buckle your seatbelt or press the brake, iirc.
Yeah, I tried a couple and they all played. Probably worth reconnecting CarPlay. For some reason when I updated to the beta I had to do that anyway because it stopped connecting to the Gravity.
Just the two buttons (x and microphone) and brake for 30 seconds until you get the release to reboot notification
did 2 or 3 time. even mobile service also did the same.
Incorrect.
Tapping the brake pedal returns your seat and steering wheel from entry/exit mode into your profile setting.
I took delivery 9 months ago and it has always worked. This is a new bug since 3.6.
Thanks for everyone’s responses. So…
1. Sounds like my DreamDrive is waiting for a software update to fix calibration or it might eventually need to go into service.
2. I tried reinstalling Audible on my phone but behavior didn’t change. Might be because I’m on iOS 27 beta, but that doesn’t make any sense because it’s flawless in my BMW iX. I’ve tried the quick reset by holding the two buttons and brake for 20 seconds, but is there a deeper reset for the Gravity?
3. Sounds like a new bug waiting for a fix.
4. Sounds like a resounding no.
Thanks again!
Thanks for posting your questions. It is one of the reasons why I am on like five different forums while trying to pick my next car. It never occurred to me that a car in this class would omit an integrated SiriusXM receiver. I had a car without, and I won’t go back.
You are on the beta? Yeah, you’re on your own. That’s how it works. I’ve got a beta on one of my devices, but not my phone. That’s highly likely your problem tho.
I need to reset the infotainment in my BMW iX from time to time as well, so I’m familiar with the drill.
I figured, most folks here are highly technical but figured I’d put it out there anyways.
It never occurred to me check to see if it had it before buying, because for years integrated SXM (with antenna) has become so ubiquitous in most car models sold in the US. It probably wouldn't have single-handedly kept me from buying a Gravity, but it has been a frustrating compromise to overcome. I know many people don't use SXM and don't see the big deal, but for those of us that do, the convenience of having 100+ channels of consistent, dependable content (other than going through a long tunnel or through a tight mountain canyon with tall walls, which is rare and very short) is a big deal to lose when AT&T cell service sucks and the car's native audio streaming systems are frequently cutting in and out.
AT&T sucks in my local area (and it's not like I live in remote Alaska, this is just north of Denver). And when it does cut out, sometimes it never reconnects for the rest of the drive (that's more than a dead zone problem). And even when there is a signal, the car's Spotify app freezes on ads. It was just one frustration after another trying to work around this to get basic, dependable audio without an integrated SXM antenna. Eventually Android Auto came to the rescue. It's not the ideal solution, and it still cuts out on some long road trips routes because even my phone's much better cell service has occasional dead zones in remote areas, but it's 10x more dependable than it was before AA.
So many compromises with this car. It does a lot of the hard stuff really well. But the easy stuff is often so frustrating.
Have you tried to connect the car to your phones hotspot using a wifi connection.... Does that help fix it?
It never occurred to me check to see if it had it before buying, because for years integrated SXM (with antenna) has become so ubiquitous in most car models sold in the US....
I use a combination of downloaded Pocketcasts, Spotify / Tidal playlists, and music on a USB drive to get us through offline areas.
No but I have mounted a Starlink Mini in the 2nd row side window on road trips to do the same thing. It works for connectivity (doesn't help the car's Spotify app freezing on ads - that's another problem). But it's too cumbersome for local drives. If I could mount it inside the roof glass in the rear, I could live with that full time, but it won't work through the Gravity's coated roof glass.
Turning hotspot on in the phone every time I go to Costco or something would be a pain too. And hotspot drains the battery too fast to leave it on all the time.
So far the best workaround has just been to go through AA. 98% solution. Just want a solution that works for getting in the car and going (like a normal car) without having to mess with it each drive to get it set up.
Since I'm using AA full time for audio now, installing the free Musicolet app has proven to be an easy way to play downloaded content on my phone through AA. That way AA just does everything and I don't even mess with the pilot panel audio screen. Plus I don't have to pay for a 2nd SXM subscription. The phone can just use our existing Porsche subscription. The Gravity can't anymore after that update a couple of months ago.
Unfortunately, I haven't been able to get AA to work in the Gravity by USB cable only. It wants to use the wifi method even when plugged in via USB cable. That's normally not a problem, unless I wanna connect the phone to Starlink wifi on road trips and still play audio thru AA. If I connect the phone to Starlink wifi, it kills AA.
To use Starlink, I have to use the car's apps instead. That means no Pandora, Spotify freezing on ads, and no SXM without a subscription. Probably easiest just to stick with AA (and Musicolet when a dead zone) and do without Starlink altogether.
If you turn on developer mode for AA, you can disable Wireless AA so it will only connect when wired.
It's not AT&T, it's the car. Driving in a Tesla through the same places were I lose connection have zero disconnects
