- Mar 14, 2022
- Dream Edition
- Air DE Number
- 532
- N92IU54F
As everyone is probably aware if you charge the LUCID to 100% SOC you will temporarily loose the regenerative braking when lifting the throttle until the battery is drained sufficiently to have capacity to draw power back in. This can be quite disconcerting when you have regen set to high and are accustomed to one pedal driving.
Apparently on Tesla vehicles (perhaps other EVs as well) a warning message is displayed on the dash to give the driver the heads up to anticipate the need to use brake pedal.
At first I was thinking to myself LUCID should do the same. But I think Lucid should do one better.
Here’s the idea:
When SOC is 100% and regen is set to high the car should automatically ease on the physical brakes at a rate that will emulate the high regen braking that is experienced when lifting the throttle pedal. This way the driver is never caught off guard by a change in the regen. Once the battery is sufficiently drained the feature is automatically disabled.
What do you think?
Here’s the idea:
What do you think?
