New Charging Knowledge Center article
My question for the team is where should we buy the AC converter so I can use my son's Tesla home charger when I visit him. The article implies we should only use Lucid approved adapters but I don't see an AC adapter available from Lucid? Am I just missing it?
A2Z adapters and cables are widely respected and used in this community. (I think you’re right that Lucid does not make their own L2 adapter)
I've been using Lectron's Tesla to J1772 charging adapter without issue for over a year now.
Me too. At home I've exclusively been charging my Air with the Tesla mobile I used to use charge my Model S with. Only get 32 amps instead of the 40 I could, but it's never been an issue fully charging overnight and I've been too lazy to "fix" something that's not broken (and it lets me keep myLucid mobile charger with the car). I have another Nacs-> J1772 I leave in the car for hotel destination chargers (that one's a TeslaTap, but functionally identical).
Nice article!
Getting ready for my 1st road trip so did a test run today to a local Tesla charging station. First thing I noticed was Tesla chargers don't show up as charging options on the car nav...any idea if this is going to be added?
When I arrived, I was able to pull in at a 40 degree angle to allow the cable to reach but couldn't get the charge to initiate. Tried downloading Tesla app as well, but no luck. It was then that I looked on the Lucid mobile app map & saw that none of the Tesla chargers I was at were compatible. Having this info in the car nav would have saved me the hassle.
I drove down to another bank of Tesla chargers in a different city and this time it worked as soon as I plugged in. The Lucid app prompted me for the charger # & started charging immediately. 3 miles per min was the charge rate, which will be good as backup.
Great to have the Tesla charging option!
I tried various Tesla to J1772 adapters on Tesla Destination Level 2 AC chargers and had to return every one. Lectron has different ones from $40 to $300. Which one works?
If you want one that will work with pretty much any Tesla destination charger, this - https://www.amazon.com/TeslaTap-Mini-J-1772-Adapter-TTMINI80/dp/B098BLLSHC
I use this one, but then again I have never encountered a destination charger over 48 amps - https://www.amazon.com/TeslaTap-Mini-Tesla-J-1772-Adapter/dp/B08T8YG63J
TeslaTap adapters are compact and built like a tank. Incredibly solid. I *think* they are also compatible with Tesla destination chargers set to "Tesla only", which I don't think I have ever encountered but do exist. I'd recommend the former, for an extra $40 if you want to be covered completely for any scenario.
That said, I have also used this Lectron one numerous times at destination chargers w/o issue - https://www.amazon.com/Lectron-Charging-Compatible-Connectors-Destination/dp/B09DCTJCTV/?th=1 (already owned it before I got my TeslaTap).
There are still some 80 amp destination chargers out there, so I bought TeslaTap's too-expensive 80-amp version before other choices were available.
Lectron and A2Z also make 80 amp adapters at a more reasonable price. I haven't tried either. One forum member had a fit issue with a Lectron adapter, but was pleased with their customer service on the issue.
Check out our new Charging Knowledge Center article, including answers to frequently-asked questions:
I recently purchased the Lucid adapter. Can I use it to charge on a level 2 NACS Chargepoint home charger? Me electrician is encouraging me to install one in my garage. The state of Connecticut is offering a $1000 rebate for the install. They offer J1772 or NACS. I am thinking that NACS is the best choice looking forward. I absolutely must verify the adapter will function properly. Has anyone tried this?
It won't work. You'd need to buy a NACS to J1772 adapter for home level 2 charging.
Note that for about the price of that adapter, you can buy Chargepoint's NACS cable kit. So you could install the Chargepoint J1772 version now, and swap out the cable if you buy a NACS EV.
However, the adapter can be useful at some hotels that have Tesla destination charging available but not J1772.
Thanks for the feedback. We will take this into consideration for a future revisions. Various noises can be heard when charging. Depending on the climate, whether you're AC or DC fast charging, or using RangeXchange, you may encounter common sounds from pumps, fans and the compressor, and other sources.
Hoping someone sees this since I added to an old existing thread - it’s really cold in Indy and my garage is below freezing at this point. I had my Pure scheduled to charge and when it started, I heard a loud grinding, squealing, strange noise. And it was charging very slowly. I stopped the charge, disconnected, reconnected the cable and tried again. The charge rate went back up to normal, but the squealing sound (coming from trunk area) perisisted. After about 15 minutes, it’s still loud, but less grinding quality to the sound. Posts here say all kind of noises will occur, so I’m curious what a normal range of sound might be? It sounded awful to me, but guessing this is a fan or pump trying to run in the cold conditions?
