In this case it actually has nothing to do with voltage (well, it does, but in a different way), but just a matter of C rate. Temperature is relevant, but there's no temperature which prevents it, there's just an ideal temperature which makes it least likely. Which is what pre-conditioning does for us. Thermally there's little difference between doing 200kW at 400v and 800v, it's still 200kW and you're probably losing like 10% of that 200kW to heat or somewhere around that, regardless of voltage. Voltage does let you do 200kW with thinner conductors as you mentioned, but the heat loss is still essentially the same. It just lets you put more cooling material in the same space where the smaller conductor now is. If you were already meeting your thermals with the 400V conductors, it won't matter though.
He explains it better than I can, but there is no magic solution. Even with perfect thermals, if you charge at a high C rate even at 70-80% SoC, you will (probably) degrade the battery significantly. It's worth a watch.
