- Nov 19, 2021
- Cupertino, CA
- Air DE-P, Gravity DE
- Air DE Number
- 241
- Gravity DE Number
- 013
- Q1BTN5Y3
Part of the reason you’ve seen so many outages recently is that updates aren’t “free.” As AI has led to more bugs being found (the easy part), that also means patching a lot more frequently, by literally orders of magnitude. Each patch must be verified, deployed, pass tests, etc. and sometimes… they screw up. The confounding issue is that in order to operate patching at AI speed, to catch up to the bugs being found, you need to use AI for that patching.It doesn't need to be Tesla in that it doesn't need stupid crap like fart noises and holiday themes, but I don't think it's unreasonable to think that a modern, software defined, high tech, luxury EV should be getting relatively frequent updates, and that included bug fixes, usability, and driver/passenger "quality-of-life" improvements.
Otherwise, what is there to differentiate Lucid vehicles from the EVs of other, established carmakers? Efficiency, and range only give you an advantage for so long, others are quickly catching up. The same will happen with cargo space and passenger room, and driving dynamics.
Then what does Lucid offer that you can't get from MB, or Porsche, or BMW?
So then things sometimes go down when that gets screwed up.
Every update is a potential failure. Small chance, but non-zero, because there are a lot of factors in play.
I do not want weekly updates. I want good updates, as frequently as necessary.
