- Nov 18, 2022
- Lucid Air Grand Touring
I appreciate the tutorial in battery temperature vs charging speed. But that wasn't what I was talking about.It’s unlikely that your batteries are at optimal temps. When you are on a road trip, your battery is warmer than normal, but unless it’s blazing hot out, your battery is almost certainly not at optimal temps for charging.
I am convinced the main issue for people who don’t get good speeds charging is they simply do not precondition enough.
Here is a recent charging session I was very happy with:
This was on a balanced 350, and I was pulling 177kW immediately, since the other Mercedes was also pulling 175ish.
21% to 80% in 27 min on a glorified 150kW charger.
But here the thing, I preconditioned for about 40 minutes beforehand, and check out the battery temp graph:
It took about 40 minutes for my batteries to get from “driving temp” of about 80ish F to “charging temp” of about 100F.
So yes, you should precondition. It can only improve your charge.
No. They do not.
Let's get grounded in some fundamentals:
> charging batteries is a thermodynamic process. As such, it is temperature dependent. "Typically", higher temperatures is favorable to accelerating the thermodynamic process, hence faster charging.
> erosion/degradation is also a thermodynamic process. As such, detrimental effects on charging batteries is also accelerated with higher temperature, correct?
> unless you are ONLY focus on the battery charging speed and don't worry about degradation, there is a delicate balance.
> from what I've read, the optimal temperature for Li-ion batteries are somewhere around 85-90 degrees F. Please correct my misconceptions.
Since half of my long distance driving originates from Phoenix going to Marin County via LA, most of the time, my car/battery temperature is already at the optimal temperature even before I started!
Did I "instrumented" my car to know I am at the optimal temperature when I charge? Hell no! But I can hear the (battery) cooling fans kick in soon after I start charging. I KNOW they are "preconditioned" even though I didn't activate preconditioning for 30m before I get to the charging station.
Now, if you living in areas that are mostly in sub-zero temperatures for a good part of the year (as I was in my younger years), the equation is quite different. In those circumstances, perhaps preconditioning has tangible benefits.
My point is, use your head and understand the circumstances and don't just blindly precondition your batteries before charging thinking you will get blazing charging speeds. For my usage model, I've found little differences!
Also, I question the "myth" of preconditioning for 30min when I am doing "daily city charging". Yes, my initial charging speed might be sub-optimal. But does it make sense to waste energy and money (several kWh and $$) to get a slightly faster charging speed just to get the thrill of it?! How does that make sense? I know "time is money". But trust me, your time is not worth as much as you think it does!
