- Apr 16, 2023
- Southern California
- ZQOO2D7O
When I pulled into my garage today, I noticed that my Lucid mobile charger was flashing red. Upon further inspection, the charger, which was disconnected from my car was flashing red. The sequence was 6 red flashes, a pause, 6 more red flashes, another pause followed by three red flashes and a white flash. Then the sequence repeated itself. The mobile charger is plugged into a 14-50 and has not been disconnected from the outlet in over a year. I pulled the plug from the outlet, let it sit for a couple minutes, then plugged it back in with the same result, pulling the NEMA plug from the mobile charger and reseating it a couple times also did not change anthing. Out of desperation, I changed the NEMA to the 120V plug and tried a different outlet with the exact same results (same flashing sequence).
The mobile charger has been in use for under 15 months but I'm guessing my mobile charger is bricked. But thought I'd throw it out to the forum members for ideas...
