Lucid Gravity 3.4.0 software update
Speaking of replacing an area of the console, anyone heard anything about being able to replace the too-tight cupholders? It's a real chore getting something like a standard Yeti cup in and out of those things.
I just use an expandable cup holder. It fits numerous size water bottles/travel mugs. Tesla cupholders are too wide and Lucid’s are too small.
Today’s set of reported software bugs, post 3.4.1
Driving along and noticed the cabin was getting warm, went to the HVAC screen to adjust temperature. All buttons on the screen, including power, were non responsive.
Also, turned right turn signal on to make a turn. After the turn, the right view camera stayed on. Even signally a left turn, the right camera display stayed on.
Did a hard reset and it cleared both of these faults. But had to cycle HVAC power to regain full functionality.
As reported previously, after the SW update, my front proximity camera no longer comes on when pulling into my garage, public parking or when close to an object in front of the Gravity. If I want this feature, I need to press the parking icon on the Home Screen. Hard resets do not fix this issue.
After the update, whenever the front parking sensors are activated automatically, you no longer see the button to activate the front bumper camera, you only see the 360 camera, it’s very annoying. The new transparency button replaced the location of the front bumper button and there’s now way to access it without exiting out and then pressing the “parking” button
The rear cupholders are the exact opposite.
I had to buy the little rubber tabs like those in the front.
I've had the front camera not display a few times on the right cockpit panel.
I shifted to Reverse, which brought up front and review cameras on the right cockpit panel, then shifted back to Drive, front camera view displayed on right cockpit panel.
You could also tap the right cockpit panel while both cameras are displayed and select Front, but I just shift into Drive.
The joy of 3D printers.
Not exactly elegant tho is it
Function over form. You can wait an eternity for Lucid to come out with a fix, if ever, or just be able to move on with life for $10.
I don’t think any manufacturer has good cup holders. Tesla Model Y cupholders are too wide so people bought adapters to make them hold smaller drinks. Lucid’s are the opposite.
My car is in service and almost ready to come "home". I only provided one key fob when they picked it up. I was told they will have to schedule a mobile tech service to update the fob they don't have. I told them I had updated the key fobs to the current software prior to handing the car over, however apparently there has to be a more comprehensive fob update that has to be done by a service tech. Might be an explanation for some of the key fob problems being reported here after 3.4.1
I haven’t had turn signal issues post 3.4.1, but my front camera is behaving the same way - doesn’t automatically activate with proximity and have to manually hit park icon. But if the pilot screen Birds Eye camera goes on, which it usually does, that means I have to X out of the Birds Eye screen and then select P icon to get both cameras up.
Weird but apparently not just me.
It’s like that ex that keeps coming back….gotta love it. The car doesn’t want me to forget how difficult things used to be..
I’ve gotten this every day this week. Car was flawless for only one week after 3.4.1. Now, 50/50 chance it Auto Unlock’s or Lock upon exiting. I’ve noticed that if the car doesn’t Auto Unlock, and I have to click the key fob (a dozen times mind you) to unlock, the car won’t go into drive. I have to sit there for five minutes shaking the key. Only if the car Auto Unlock’s can I get right in and drive. Key fob is up to date, replaced the battery again this week, still issues persist. Have rebooted every day. Anyway, happy Friday.
Never seen this error message before!
My Key Fob has been consistent since delivery in December 2025, and is still using original battery.
If there were Key Fob issues, they were never apparent to me.
Does anyone see a degrading performance of 3.4.1? I have started to see a gradual return of the Gravity's greatest hits, after being mostly gone after the update
Only intermittent issue I've noticed is 1-2 second delay to show blind-spot camera view when turn signal is activated.
It usually resolves itself after power cycling (park → exit → lock → return → enter → drive).
Mine's not so bad. But walk-away lock didn't work yesterday.
This is with latest SW in fob and car, and a new battery.
I find that the key card is reliable but it is not convenient, especially when it's raining.
Never had the problem of "car not going into drive" with the key card.
I always carry the key card with me.
I have a 48 amp home Tesla charger that was charging at 11kW and might slow to 8kW pre software update. Now that the new Update has been installed the charging at home process has slowed and as the battery reaches 70% overnight it slows to 4kW. Anyone else notice this change? rebooting doesn't affect his.
Update for those who noted this issue, the day that I had a slow charging experience, I also had a loss of WiFi and rebooted the car when I returned home. Last night I charged again and was rock solid to 95% charge. I suspect that I experienced a fluke and the reboot fixed everything that was not working correctly including the WiFi which came up instantly after the reboot. Thanks for your comments
Unfortunately that probably won't be the same for me as I had rebooted a couple times to test charging and for other issues like cameras.
Regardless, happy for you its not an issue anymore!
today, my front camera worked perfectly during a tight parallel parking maneuver. 🤷‍♂️
Anyone else not yet receive the update, or am I alone in still waiting?
