Kids and gear for Gravity
Bryan_MSP
'21 Mustang Mach-E
Hi everyone! Found this forum today and love the information on here! I ordered a Gravity in December after the arrival of my twins and looking to upgrade from my Mustang Mach-E. Looks like I am the first to order a Gravity in Minnesota (at least from the tracker). 3 car seats in the MME has been tough, at best (2 infant carriers and a forward-facing convertible). Those that have seen Gravitys (Gravities?) in real life, any thoughts on how car seats would fit with 3 kids? 2 of the seats will always have to be the same for my case, and after delivery, it will be short lived with infant carriers, but rear-facing convertibles. Is there enough room to have 2 in the middle (60% of the bench) leaving one outboard seat available to access the back with a forward-facing car seat? I have seen the comments about some difficulty getting into the third row, but young kids are flexible enough to get back there no problem.
The other question I have is if a folded stroller of 37" x 28" x 14" dimensions will fit in the trunk. I saw the post on reddit with the dimensions outlined, but not sure what the distance is between the top of the third row seat and the rear hatch. This is the StollAir TwinWay Double Stroller (Highly recommend for multiples, or if you want 2 kids to sit side by side).
The cargo capacity sounds impressive, and with the below floor storage, I think the stroller will fit, but not sure how accurate this picture is: (Autopian Review).
The Gravity seems like such a better vehicle than any other 3 row electric that is available - and after having electric, I am not willing to go back to gas (or even hybrid). Hoping to join the Lucid family with my now expanded family!
You can fit two car seats side by side in the third row, and they even have the latching system for car seats in the third row iirc; someone will have to double check that because I haven’t verified it, I just recall hearing it in a review.
You could fit three side by side in the Air back seat (@hydbob has done it) and so I’d be surprised if you couldn’t in the gravity.
The second-row outer seats are equipped to accept LATCH/ISOFIX restraints. Only a seat belt-retained child seat can be used in the second-row center seating position, similar to the Air.
Truthfully, best way to find out is to go to a Lucid Studio with tape measure to verify dimensions. Lucid reps might even let you try fitting your stroller in the Gravity.
Just be at the door as soon as the Studio opens and make sure that your stroller is clean, especially the wheels.
Good diagram! If the middle row is wider than the MME, this could definitely work and have the two rear-facing in an outboard and middle position, with the front facing in the other outboard. Only use third row when needed with family in town.
I was thinking that. The closest studio is in Chicago - have people traveled to studios to check these cars out ahead of delivery? I was hoping I could contact the mobile service center in Minneapolis and see when a Gravity may be there to check this out.
Big ask, in New York I had to beg to put a pen through the firewall to even get close to the outside of a wheel to measure distance.
This is truly the big question. You usually have to go up to the full size class (Expedition, Tahoe, Yukon, Escalade, etc...) in order to get a wide enough bench to put two car seats side by side.
In the Air you CANT do this if one of the seats is occupied with a carseat. (maybe for 3 adults you can). But I've tried to carry 2 adults+baby in car seat in my Air, the the middle seat is incredibly uncomfortable to sit in. You have to lean against the other passenger. (Also had my seat belt chime going off the whole time because it was impossible to get middle seat passenger squarely on top of the seat occupied sensor.
You would definitely want to test fit in a demo when they are finally available. Lucid sales associates are super chill regarding this. I've seen people swing by the studios with strollers and trying to stick everything in and seeing how it all fits. They even drove an Air to my house so I could test fit a single car seat.
I use Diono car seats, 17” wide and easily fit two, front and rear facing with a passenger side seat open for any adult. In an Aviator which is similarly wide.
LOL.
First, call ahead to introduce yourself and express your serious intent to buy a Gravity; even better if you've already reserved one.
I arrived very early, right before the Studio opened. I was the only one inside for the first ~15-20 minutes.
They let me inspect almost every inch of it. I was wearing disposable gloves so as not to worry them about fingerprints. Only thing I was not allowed to do was sit inside.
However, very soon, many Studios will be receiving Production Gravitys for customers to experience and test drive.
I've done 2 front facing and 1 rear facing in the Air just fine. I was using the Graco 4ever-in-1 and the Chico whatever with the detachable carrier at the time.
I've done 2 front facing and 1 rear facing in the Air just fine. I was using the Graco 4ever-in-1 and the Chico whatever with the detachable carrier at the time.View attachment 26160
Seeing this is very helpful! Getting three narrower seats and having two rear facing next to each other and the forward facing could work!
I've managed to fit two rear-facing seats side by side in the back of an Air, though it required test fitting multiple seats and was a fiddly affair.
I found two setups that worked acceptably:
1) Diono Radian 3R (convertible) outboard rear facing with a Nuna Pipa + base (infant) rear facing in the middle seat. This one worked pretty easily since the Diono is such a slim seat.
2) Graco Extend2Fit 3-in-1 (convertible) outboard rear facing with a Nuna Pipa + base (infant) rear facing in the middle seat with the Pipa lifted up slightly on a Diono "angle adjuster" pad so it would clear the Graco's fixed side mounted cupholder. Fiddly to setup, but doable.
My toddler didn't like the Diono, so we ditched it, and the infant is now big enough that we have an Evenflo Revolve 360 in each outboard seat and have written off using the middle seat for carrying people of any size.
With slimmer convertible seats I fully expect you could fit two rear facing in the outboard seating positions and have a forward facing seat in the middle, I just couldn't say precisely which seats would fit the bill.
This whole conversation is prefaced on the Gravity's second row being at least as commodious as the Air's, of course, which seems like a reasonable bet.
I've been thinking a lot about the ingress/egress to the third row for kids/carseats. I really like that the seat belts for the outer 2nd row seats are integrated into the seat itself.
It has me wondering if the normal 3rd row access button would operate with a carseat installed with the seatbelt? Obviously the seat back couldn't fold forward, but if the seat would automatically slide there still is probably room for a child to sneak back there. There could be some issues if the seat back tries to fold and needs locked back into place that could mess up the carseat installation. When we check out the Oakbrook studio Gravity I may try to replicate this by sitting in it with the seatbelt locked and pressing the access button or something.
Another great thing is since the 2nd row seats fold so flat, older kids may be able to easily climb over into the 3rd row. This would be helpful for the one of the original questions in the post asking about 3rd row access if two carseats are installed in the left and middle positions. You wouldn't have to worry about the middle carseat installation completely clearing the right seat.
Normal 3rd row access when pressing button on side:
Seat completely folded:
Also, I may be one of the few that care about this, but I will put in the information that @TribbleTrouble and @borski generously provided about width of seats in the second row that the OP originally was asking about:
Full Bench Width: 52"
Center Seat Width: 13"
Outer Seat Width: 19.5"
Pictures of these measurements in the thread below:
For what it’s worth, I visited the Oakbrook studio today near Chicago and spent a while going over the Gravity with my SA.
I was amazed at how low the step in height was, even with the cars suspension at max height. It would be great for kids or people who would have a tough time climbing up into a high vehicle.
I also tested 3rd row entry as I mentioned in a post above and verified that the 3rd row access buttons on the sides of the seats don’t work (no tilt or slide) when the seat belt is fastened (to simulate a forward facing car seat). I’m sure you could slide the seat forward with the lever on the bottom cushion, but that would be tedious.
Other observations:
-Seats were extremely comfortable
-Can confirm leg room is amazing. I am 6’5” and sat in all 3 rows comfortably at my driving position. It felt much more roomy than a recent BMW X7 M60i loaner that we had.
-My head didn’t touch the glass in the 3rd row if I reclined the seat back which was also great.
-Visibility was fine for me; our current X5 has a big A pillar and this felt like overall visibility is even a bit better in the Gravity.
