Is something wrong? 90% == 293 miles
Rpomeroy
2027 Gravity Grand Tour
So it’s my first couple weeks with my 2027 Gravity Grand Touring 5 seat with the smaller range focused wheels. It’s advertised as having 450 mi range.
I set the charge limit to 90% and charged it at home with a Tesla wall charger. When it finished charging to 90% the app displayed a dynamic range of only 293 miles - slightly less than my 2017 Tesla Model S P100D.
What am I missing?
I beleive that dynamic range is based on relatively recent driving history. It likely has not had time to 'learn you' yet. If you are trying out the acceleration and power of your new car, it will be reflected in the dynamic range.
It’s “possible” (wink wink) I’ve been enjoying the brisk acceleration - even in Smooth mode. I’ll give her some time to get to know me. Thanks for the info.
I believe they say it takes about 2,000 miles before it becomes more accurate. That said, don't expect anywhere near 450. Probably closer to 350-400.
I've found that the Dynamic Range numbers are quite conservative—maybe it's designed to make sure you don't get stranded or run out of power—but it's consistently 8–10% less than what you'd find in the trip info pages on your historic kWh. Basically, know that you can probably go further/are more efficient.
People call EV range displays GOMs (Guess-O-Meters) for a reason. It's only an estimate. It's impossible for the car to know how and where you're doing to drive, what the temperature and wind will be, etc. It just knows what it WAS on your more recent drives and assumes the same (which is often very different).
For instance, I just got back from another 2500 mile road trip, with my worst range leg yet. (I too have the 5-seat small wheel 450 mile trim.) Left Green Valley Ranch in Las Vegas with a 100% charge and made it to the Tesla Supercharger in Ely NV 257 miles away with only 5% left. Calculates to just 270 total miles of range. I think that's my first sub-300 range leg. There is a 4300 foot elevation difference which always costs some range. But temperature was probably the bigger factor. This was the first cold trip I've done in the Gravity and the difference on that leg in particular was stark. I did that same drive in Aug and again in Sept. I don't remember exactly what I arrived at then but I think it was over 20% both times. The charge log shows 88 kWh delivered in Sept, and 112 kWh this week. Huge difference. And it wasn't even super cold this week, just around 40F most of the way.
The Dynamic range efficiency for that leg never dropped below 2.56 MPK (mi/kWh). But the whole leg calculated out to 2.36.
Strangely though, the rest of the legs home in similar temps were not nearly that bad. Worse than summer legs, of course, but there was something about that one leg to Ely that was extra bad. I didn't notice any wind (another common culprit). I'm puzzled on that one. First time I've had range anxiety in the Gravity. Was watching the estimated arrival% steadily drop down to 7%, at which point I turned off the cabin heat, turned on Energy Saver, and slowed down from 75 to 68 MPH for the final hour. That's a charging desert so making it to Ely is do-or-die.
This is my 6th year of heavily road-tripping EVs so I'm familiar with the routine. But each EV is a little different, particularly with how much cold impacts it. Reports from the usual YouTubers suggest the cold affects Gravity range even more than most, so I knew to expect it. But I was still surprised to only see 270 miles of range on that leg, especially since it wasn't even below freezing yet. I'll have some trips that will get down to 10F-20F.
What am I missing?
The dynamic range is based on relatively recent driving. If you look up your trips, you'll see your miles per KWH for each one (A and B) and since last charge. With brand new tires and likely some use just before you got it, and maybe learning the vehicle, you may see a startling low value. I started out with 2.8 - 3.2 miles per KWH, and now average 3.8, with 3.6 on longer 70 mph road trips. It took about 1500 miles for the numbers to stabilize. And if you own the car (as opposed to lease), I'd recommend routine charging to 80%; use higher when you're starting out on a longer trip.
I'll toss in that I agree with the 2000 or so miles, but with the Gravity GT 7 passenger version and best mileage wheels/tires combo, I average 3.8 miles per KWH, and easily exceed 460 miles range with the EPA for the 7 passenger being 437. Around my area (Cape Cod, MA), I can easily average 4.2 miles/KWH, or over 490 mile range.
3.6??? In my dreams. I average 2.8 MPK on the highway in the summer. Granted, half of those road trip miles are at 80 MPH instead of 75 or 70, but I don't sniff anything close to 3.6 on the highway, even at 70-75.
Umm...yeah. We don't have the same car apparently. Unless you are driving downhill or averaging 25mph the entire time...
Same... never seen 3.8 or even close
My 5seater GGT (20/21's) averages between 2.3-2.7
Apparently my right foot is too heavy to enter this conversation 😂
Thank goodness for solar and home charging!
I've never reset Trip B. Over the 10 months we've owned our Gravity GT we've averaged 2.98 miles/kWh. Ours is the 5-seater with 21"/22" wheels, so I think EPA is 407. Taking our average of 2.98 times the 123 kwH battery pack, we're looking at 367 miles of range. Kind of disappointing, to be honest, but it is what it is. We don't drive it hard, but do a lot of short trips, mostly rural roads and highways, with occasional long road trips at 70mph.
Note: The tire pressure display on the dash always read 42 psi. When I put an actual tire gauge on them, they were mostly 38 psi. Not sure how much of a difference that might make.
Here's mine. Trip A is lifetime, trip B is the road trip we did the last 2 weeks. Roughly 75% of our miles are road trips with an average speed of 75 MPH. 5-seat small wheels (450 EPA).
Did Lucid implement the range shown in the car differently between the Air and the Gravity? Air does not do dynamic range as far as I know. I have always seen the same no when I charge to 80%.
I haven’t seen anyone hit any of those numbers reporting out on Gravity…so wow! You are the title holder by far! We need to study your car or something or all move to Cape Cod!😂
Wow! You've gotta tell us more about what kind of speeds and conditions you're driving in to achieve that range. People's efficiency reports vary a lot, but yours is the highest I've seen, by a significant margin.
