Interesting Results from Recent Road Trip
illopp00
14 CR-V EXL, 24 Air T
Just got back from a day trip. There were some unexpected results.
Conditions: 50 Deg F ambient, mild traffic. 136 mi Total. Average highway speed on ACC was about 70 mph. It is a 2024 Air Touring on 19in with Aero Covers. 2 Adults, 2 kids in the car. HVAC in the front set to 68, rear 70. Used some seat heating and massage for 30 mins of the trip. Smooth mode with High Regen.
Since Last Charge is the full trip which included a little bit of city.
Trip A by habit I normally reset around 88-92 Kwhr to represent a full battery charge.
I thought there was something wrong with the car on the trip there with low efficiency, and then it magically made crazy efficiency on the last leg my wife was driving at about 69 on the highway. There was some traffic that included rolling downhill at about 10 mph for a few minutes. The only other difference was that normally my son likes his HVAC zone on manual so that the fan speed is constant. So 1 zone out of 4 was manual. I changed it back to Auto for all zones.
This is exactly what I get in Florida with 20 inch wheels at 80 degrees weather . Not very close to advertised
It seems you’re implying that Lucid lied. They did not. They quoted the EPA in their advertising and clearly said your results will vary. EPA is achievable when duplicating test conditions.
I find that conversations like this are far easier to evaluate when elevation change enroute is part of the dialogue, and on some occasions head or tailwinds to boot. For example, a lot of uphill on the cold part of the day would look awful relative to the downhill return on the warmer part of the day, and the two do not necessarily offset. Same with head or tailwinds, which can be good or bad in BOTH directions.
I guess what I was getting at was there a significant drop in HVAC consumption between using manual and all zones in automatic? I looked up the elevation change it was about 40 ft.
Ha! It sure wasn't the 40 feet! It's hard for me to believe that the differences in your HVAC usage would account for all that much either. Strange.
I don’t know how you got that from my answer but ok …
net elevation change of 40', correct? but hills in the middle take energy to climb and the regen is less than 100% efficient for the downhills.
Let me ask some awkward questions (not just to Bobby, anyone can chime-in):
> Yes, Lucid was simply quoting EPG numbers, hence they are not lying.
>There is no implied guarantee that you will get the EPA range unless you replicate the exact EPA test condition. Right?
> Isn't EPA testing done on a dynamometer? If YES, was there any wind-resistance effect in EPA rating? Or is it "derated" using a "fudge-factor" to account for the "unknowns"?
> It is well debated in this forum that speed and wind resistance is a BIG part of the efficiency, hence the achievable mi/kWh, correct? If so, how is a scalar "Fudge-Factor" going to account for a quadratic wind resistance effect? In other words, is EPA rating meaningful in any real-life highway driving condition when it comes to efficiency?
> Now, WHO decides on the "Fuge-Factor"? Is it the EPA? Or is it "in conjunction" with the auto manufacturer? Or do the auto manufacturers simply tell EPG what number to plug in?
> If the "Fudge Factor" is determined in conjunction with the auto manufacturer, why are Tesla and Lucid significantly worse when independent tester compare than EPA achievable mi/kWh whilst the Germany manufacturers often met or exceed their mi/kWh rating?
Feel free to correct any mist-statements on my part.
Wouldn't the process be the same for every single vehicle they test? Eg aerodynamics impacts every single car. I would assume they use the tested coefficient of drag for the tested vehicle as that's a known and proven number.
Correct, except it's the EPA.
Correct, because that is how physics works, yes. It is also not guaranteed that the temperature tomorrow will be the same as today or that there will be more or fewer cars on the road or that there will or won't be a power outage. Hell, one of us may not even wake up tomorrow.
The whole point of the EPA testing is to test vehicles under the same set of conditions, providing us with a relative comparison for their efficiencies. It is not and was never intended to be a 'promise' or 'guarantee' of what you'd get under all conditions. That would be an absurd question, given how many factors there are.
It is unfortunate that the EPA offers two methods of testing, a 2-cycle and 5-cycle test, thus muddying their goals of it being a valid relative comparison, but nevertheless, that is not Lucid's fault.
Yes. I have no idea. Yes, it is 'derated' using a 'fudge factor'.
No, it is not well-debated. It is well-understood as fact.
Yes, because it is meant to be a comparison relative to other EVs, in addition to a meaningful estimate for travel. Moreover, plenty of people achieve EPA range, just not in cold weather and driving 85mph+. Drive like the EPA, and you get EPA range.
The EPA applies a 0.7 adjustment factor, effectively reducing the laboratory-tested range by 30%. While 0.7 is the most common, manufacturers can use a different adjustment factor if they believe their vehicle will perform better or worse in real-world driving conditions than the 0.7 factor would suggest. Tesla is an example of a manufacturer that uses a different factor. Lucid does not.
The adjusted city and highway range values are then weighted (55% city, 45% highway) to calculate the combined range displayed on the EPA fuel economy label.
Because, for the sixteen thousandth time, they use the 5-cycle test, and other manufacturers use the 2-cycle test.
That's it. There's no conspiracy. That's the end of it. That's the reason. Believe it or don't, but it is the truth. That is the reason. Please stop asking the same question and seeking a different answer. It is very, very annoying. There is no other answer. This is the answer. This is the correct and only answer. Lucid and Tesla use the more expensive, but better looking, 5-cycle test. The german manufacturers use the 2-cycle test. That is the reason.
In case you missed it, Lucid and Tesla use the more expensive, but better looking, 5-cycle test, so their numbers look better than the German manufacturers, because the German manufacturers don't spend the money on the additional testing. It isn't because the German manufacturers are somehow better people to their customers and are altruistic.
The reason is Lucid and Tesla use the more expensive, but better looking, 5-cycle test. The german manufacturers use the 2-cycle test. That is the reason.
In addition, Tesla adjusts the fudge factor to make theirs look even better. Lucid does not.
(To be clear, the sarcasm in this post is not directed at OP or anyone else in this thread. @BS8899 has been after this EPA range conspiracy for as long as I can remember, which is likely why I have tired of it, and I know I'm not alone. I apologize for my tone, but I'm tired)
