I've driven my Lucid 128 miles since the last charge (100%) earlier this week. The battery shows that it has 50% left. Based on this reading I will get 256 miles out of this charge. My efficiency since last charge is 4.3 mi/kWh. That doesn't add up.
Even assuming a 70kWh battery (rather than the 92 kWh battery in my 2024 Air) to allow for a huge buffer, I should still be able to get over 300 miles at that efficiency. Using the 92kWh battery I should get over 400 miles.
One of the readings has to be wrong but I'm not sure which.
Anyone else had this problem?
