How to disable charging via the app?
steveairgt
Atlanta, GA
Lucid Air Grand Touring
83YOVHQD
Hi
When I go away on vacation I usually leave the car plugged in and the limit set to about 70% or so.
When it falls below the limit it starts charging again which is ok.
When I’m within a few days of coming home it would be nice if I could disable charging so it doesn’t continuously start and end charging sessions.
I don’t see a way to disable charging in the app.
Suggestions?
Thanks
Depends on how long you will be gone. Charge to 80 and leave it unplugged imo
If less than 1 month and you're not parking inside a 2 car garage in 80+ degree weather, then this is a great way to proceed.
Alternatively, charging to 90% then setting the limit to 50%, then leaving the car plugged in is a phenomenal idea since it won't charge unless it needs it and you can adjust the limit back up when you're on your flight back home.
Lower the charge limit to say 50%? I'd imagine that would prevent it from charging for a while.
