How much reserve charge does Lucid hold back?
AwesoM
Richmond VA
2024 Lucid Touring
Air DE Number
0
Does anyone know how much Lucid holds back for battery reserves? We have 92KW on our Touring, Im pretty sure we do not have access to all 92KW. Sorry for all these questions, trying to understand our new car 2 days in. This would let me have a better idea what the true range is since in reading in this forum the GOM is pretty inaccurate.
Thanks
Did some basic calculations, I had consumed about 26kw and my SOC was at 70 percent. By that estimate, it would suggest on the touring with a 92kw battery, we have access to about to about 87Kw. So Lucid hold back about 5 percent or so. Is anyone able to confirm the same? Reason is to understand what true range I have left when I am traveling.
I have a touring as well, I think they claim 92KW is net, so that is what will happen if you get to 0% SOC, there is generally a couple 2-3KW (`~10+miles) left in the battery as buffer based on the online tests where they drove the car until it stopped dead.
I just did a post on an anecdotal test.. I came up with about 87kw. I looked at my trip info showing how much I had consumed since last charge and looked at the SOC to come up with that number… thoughts on methodology?
If you do the software system check as described in the forum, I get an actual capacity of 88.9kwh. You can check yours just follow the link. There is a ton of information in the forum just search for it.
Hi @Daniel2022AT was there suppose to be a link in your post?
As near as I can tell, Lucid keeps about 4kWhr below zero SOC as buffer. This was recently confirmed by the range test done by Kyle Conner also.
Yes but that was on the bigger battery GT.
Just ran the link... capacity_kwhr: 85.82999808155, about 6.7 percent.
There likely is some degradation from new too, I believe the first 2-5k miles.
I recently charged my 8 month old Pure AWD's 92 kWh battery to 100% on a slow charger, and it registered 409 miles at 100%. That's just 1 mile short of the 410 mile EPA estimate on the window sticker. At 92 kWh, the EPA figure comes in at 4.46 miles per kWh. People who have really pushed the envelope have reported as little as -17 miles on their dashboard's EPA range indicator. Please correct me if my logic is flawed, but that suggests to me that there is about a 4 kWh buffer, although it's hard to be precise, as that -17 mile car was still operating. Nice to think that there is about a 4% buffer. I wonder how many launches you could get away with at zero range?
We have a BMW IX and previously an I4. The GOM in our LUcid reminds me of the I4.. very inaccurate. Which is why important to figure out how much battery available to truly figure out ones range. The BMW IX does a much better job and is almost correct in its estimation has it has an average algo it is using. Perhaps I need to "burn in" my vehicle before things are more reporting more accurately.
Multiply your battery health by 92kWhr before subtracting your capacity.
Holy cow... my battery health is 96%... how can it be 4 percent lower for a vehicle that has less than 300 miles?
Thanks for calling it out... so 0.96 * 92 = 88.32. With the capacity at 85.83, then the true reserve is 2.49 KWs.... is that right?
Nothing to worry about.
1. This is neither an endorsed nor accurate method of measuring health - as it says on the page, asking your service team is the only way to get that.
2. Sitting time also affects battery health, not just driving time. Check your production date, not just your odometer.
3. Most of your degradation will occur in the first year or so, then taper off.
My battery health is also at 96%, and has been for at least the past 6 months or so. My car was built in Nov 2022.
I have 2 months old pure and battery health is 95.6%. My theory is that includes reserve capacity + degradation. About 4% reserve and .4% degeneration. It is semi informed by the miles range car is reporting using the EPA range that is about 4.75 miles per KWh for my Pure RWD. I might be totally wrong but that is my running theory for now.
if the math works.. I have been doing some highway testing going at 70 mph and AC at 72 F with blower set to 2 at both sides (rear off) we are getting between 4.5-5.0. This is promising for road trips. Admittedly I have a lead foot, I drive our BMW IX like power is free.. (it kind of is since we have 2 years at EA ..lol) Wife wants us to do a 350 mile trip to see if we can make it without stopping to charge.
Wow! That's insanely good! 19" tires with aeros on? Are you somehow always going downhill with the wind at your back? :)
From my experience driving 2023 Pure AWD (essentially the same as Touring) for a year and 12,000 I get about 200 miles between 80% down to 20% of normal driving mixed city/highway without hypermiling. Steady driving at highway not going beyond 70 miles would generate even better results. As you correctly noted there is about 88KwH usable battery.
