Heater and Defroster Not Working - 2023 Lucid Air Pure
LuanDo
2023 Air Pure
Today my Lucid Air Pure heating system stopped working and displayed messages letting me know that the heating system and defroster are not working and advising me to schedule service. The car had been performing well for the past 11K miles. Odometer has almost 22K miles. This incident seems like the first major issue the car has had. Anyone with heating system issues? Lucid had no loaners available and said a rental would be provided. I only got an Uber ride home, after dropping off the car.
Mine just did the same thing a few days ago. Also, the navigation system thinks I am parked at the San Diego Airport, which I haven't been in 5 days.
My 2022 Lucid Air Grand Touring did the same thing a few days ago. I'm 100 miles from a service center so I'll keep checking this forum to see if an easy fix appears. I have logged 44K miles. Any chance the heater is still under warranty? Thanks.
It's likely the known problem with some early Air heating modules. If it is, service will need to replace the part.
Yes this was the first symptom of a major problem that ended up like this.
Yikes. Thanks for the info. That's scary. It went from a heater problem to the car needing to be towed?
Same here. I'm assuming. There was a 2 month lag between no defrost warning and bricking. So there may be no connection in my case.
Thanks kindly for the info. If the pattern happened to more than 1 car, then that's a non-zero correlation (even if there is no direct cause-and-effect). And that's enough to get me out of my energy saving mode and get it fixed next week.
