Fellow hams;
I think there needs to be a dry run before any detailed install as there are other considerations I would be concerned about:
1. Electromagnetic interference: look at the power you will be tx’ing and the frequencies you will be on depending on your license level. While most modern designs accommodate non-bleed over components, I have experienced bleed over when I it was not properly planned especially when using the power that a licensed ham is able to transmit.
2. Power draw: While I love my lucid, I am not confident in drawing more power out of the battery until the battery technology gets to a point in time where range is no longer an issue since the advertised numbers don’t take into account that most owners don’t want to leave the battery to dip below 20 percent charge and not go beyond 80 percent for daily driving. This sixty percent leaves me with approximately 229 miles range on an AT with 20 inch rims, when I drive under the speed limit.
3. Proper grounding & emergencies: while I love the battery safety protocols and insulation from the high voltage systems, my educated guess is that you really have to think about what happens in an emergency or collision. Will the ham radio install make a bad situation worse whether through loosened wiring or an auxiliary battery?
4. Temp management: goes with out saying that the transceiver will generate some heat, placement of equipment will need decent airflow which is another drain on the battery.
I still think it’s doable but needs a good implementation plan and some tests to validate assumptions and potential risks before any drilling or installation happens.
I like to keep my ham radio and gmrs radios on a go bag with extra batteries so I can use as need
