- Mar 7, 2020
- Naples, FL
- Air DE-P, 2 Gravity DEs
- Air DE Number
- 395
- Gravity DE Number
- 067
238
- 033M4EXG
I think there might be some confusion. This is not “mobile key” as in the Air. This is a separate feature, named remote start, which kicks off a two minute timer so you can drive the car without a key present.
I understand that now, but the email was misleading. It says this feature brings "keyless driving to the Lucid Mobile App." That sounds an awful lot like a mobile key to me. Yes, they call it "Remote Start", but that is immediately followed by a parenthetical definition of Remote Start as "keyless driving".
The Air does not have a “remote start” feature.
Neither does the Gravity if the car is plugged in.
I guess I don't understand why you should need two steps to use this feature if the cable is plugged in. If you want to start the climate control before you approach the car, you could already do that with the app. If you want to stop charging while being away from the car, you could already do that with the app.
The only purpose of this feature is to unlock the car and power it up so you can get in and drive away promptly, meaning you're already near the car . . . hence the boast about "no breaking your stride" in the email. Why not just unlock both the cable port and the doors at once instead of requiring one step first to unlock the cable port, a second step to unplug, and a third step then to unlock the doors?
Take the scenario when you're plugged in at a DC fast charger. You get the charging underway and then decide to go to the bathroom or somewhere to get a snack. This feature won't get you back in the car unless you terminate the charging session. To avoid that you would have to have your key fob or key card on you, the need this feature was meant to alleviate in the first place.
