- Aug 23, 2020
- Paradise Valley, AZ
- Air GT, Gravity GT
- K9WIJHB0
Can you elaborate a bit on the use of the rear motor to boost the DC? Physically, how is that accomplished?
I thought it would be better to create a new thread for this since it is Gravity technology rather than deliveries.
A basic DC to DC boost circuit requires an inductor, a switch and a smoothing capacitor. The circuit works by taking advantage of the property of an inductor where its voltage will rise as it tries to maintain a constant current. The switch is used to change the current through the inductor and thereby increase the voltage across the inductor. The switching frequency controls the amount of voltage boost. The smoothing capacitor helps make the output voltage constant so that it can be used for battery charging.
The stator of an electric motor is a large inductor, the motor inverter is multiple switches. Hence, most of the components for the DC to DC converter are already part of the motor. Lucid was issued patent US10505455B1 on Dec 10 of 2019 for this DC to DC boost methodology. A figure from their patent helps illustrate how it works. Contactor1 bypasses the motor boost circuit for high voltage chargers, Contactor2 engages the motor as a boost circuit. The advantage of having three stator windings is that currents can be interleaved and phased to minimize motor torque and reduce ripple on the boosted voltage.
