- Dec 26, 2022
- Grand Touring
I think there is a serious flaw in the location of the Frunk's internal "close" button. At least, I think that's the problem.
I had a tool bucket in the Frunk. It's a five gallon paint bucket with a cloth pocket system. It's not particularly heavy - maybe 20 pounds that day. Certainly less than a full flight case.
There was a backup at a freeway exit, and I had to execute a sudden speed reduction as I turned at the top of the ramp. My Frunk contents possibly shifted - at least, I think I heard that. When I completed the turn and got to a stop, my car complained that the Frunk was open. The car would only allow me to move very slowly, and I had to turn on flashers and move slowly out of the way of traffic, to the considerable irritation of those behind me. I pulled over a few hundred feet ahead, and indeed the trunk was partially open. I was able to simply press it closed with my hands.
I am of course glad the Frunk didn't fully open, and that the car refused to let me drive fast with an unlatched Frunk. Kudos.
After looking inside the trunk, I'm guessing that the tool bucket bumped that "close" button. Is it possible that the button functions as an "open" button when the trunk is closed? (Anyone want to get inside and test?)
Or possibly the frunk contents bumped against the closed frunk hatch and caused the latch to be overwhelmed and release.
Either way, it's a significant problem, and because it leaves you "stranded-ish", and that makes it a safety issue.
If it's caused by the button, that is a design flaw on the position of the button. The button should be positioned so that contents cannot operate it. The current position makes it possible for contents to bump into the button. Of course, a software fix would be to ignore the button as an "open" button and just use it as a "close".
It the problem was caused by the contents bumping into the hatch, I'm concerned that the latch is inadequate to the purpose.
I hope the problem is #1, and fixable by software.
Has anyone else experienced this?
