Fans running after wake up + losing battery %
FM7
Riyadh
Lucid Air Touring 2024
I live in a very hot climate, and today the car for some reason decided to wake itself up (I realized because Bluetooth on my phone got connected to the car). And the car fans were running very loudly, I'm assuming to cool the battery. I had it charged to 80% yesterday and unplugged. Checked on it and it was down to 78%. I went down to check on it and made sure to it was locked.
Later in the day I opened the application to check if the car will wake up (I've been having problems to get it to wake up through the app lately so I occasionally check). And whenever it wakes up the fans go crazy again (the doors are locked and AC off). I check the battery and it's down to 76%. Lost 4% and I haven't even moved the car. Is this normal?
Mine does the same thing. It appears that the car is running the AC to cool down the car for us humans
If you have proximity unlock on, that makes sense? You're getting your key close to the car, so it wakes up and turns on the human A/C. I've never noticed it waking up on its own just to condition the battery.
I always turn off AC and Music manually before getting off the car to avoid this battery drain. My bedroom is next to garage and mobile key wakes up the car quite frequently. This manual step although inconvenient avoids unwanted battery drain.
Turn off passive unlock.
I know. But I do like the feature so the mentioned workaround is what I prefer to use the feature yet preserve battery drain. May be OP may want to try this.
You could also switch off your Bluetooth at home… 6 of one, half dozen of another🙃
I was out of town for 5 days and my Lucid Air was home in the garage. The key fob was inside the house (too far from the car to be detected and no one was home). While away, I was checking for the 2.4.x OTA 2-3 times/day, thus waking-up the Air that many times (the app showed the Air is locked at all times) Is it normal to lose 21 miles (260 to 239 miles which equates to about 8% of initial charge) with this wake-up activity? The OTA did not arrive - still waiting for it.
You will lose about 1/4 of one percent each day when the car is just sitting there, and much more every time you wake it up. Because the miles indicated are based on EPA, 21 miles is more like 5%.
The 1/4 percent per day used to be a good estimate when the car is sitting without waking. However this was improved earlier this year and I typically only see 1% drain in 10-12 days now. Waking the car multiple times per day will substantially increase the drain.
Here's an update for those facing the same issue, turns out it is indeed proximity unlock as others have predicted in this thread. My room was close to the garage and apparently the car was waking up without me knowing, didn't notice it in the Winter, because the AC didn't need to turn on.
So I simply disabled passive unlock and it never happened again.
