RESOLVED Destination sharing from Apple/Google Maps is broken in iOS 26
Ah, just tried it, and it seems to be broken with Apple Maps! I'm sure it'll get fixed soon, but definitely email customer care.
Works fine from Google Maps.
Thanks for following up and realizing we weren’t lying! Also by you mentioned Google Maps I was able to use google and that worked, I’ll have to see if the car will accept it and actually map it next. Thanks!
Does anyone have a different car they could try sending both Apple and Google Maps to in order to find out if this is an IOS 26 issue? IOS 26 is pretty buggy.
Worked from Google Maps on my iPhone running iOS26 to my AGT. Apple Maps does not send to car.
It only became an issue on iOS 26, and only with Apple Maps, so it is definitely an iOS 26 issue, but not necessarily one that Apple has to fix. Might be one that Lucid simply has to update an API call or fix something for iOS 26.
Everyone running iOS 26.0.1 right? That update is kinda buried in the Software Update screen and not prominent if you don’t go look for it. Setting, General, Software Update, then look at the bottom.
Yes and it doesn’t work, car and app are both current
Just did it from my phone and it worked fine.
iOS 26.01. Apple Maps. Newest Lucid app, and the car is up to date.
Problems are not unique to iOS 26. I am on iOS 18.7.1 and it only transfers the address to the lucid app but then the car doesn’t do anything to map to it.
I just tested it a minute ago; from Google Maps, it shows up on the right cockpit panel when I get in the car and then I can tap it and nav routes to it.
I am running IOS 26.2 and app version 2.11.0 and am having this problem with Google Maps. Worked a few months ago when I last tried, and now does not.
Anyone have any tips for what to investigate, to debug or fix it?
I’m getting the same message.
Yes same message here for Apple Maps, too. Was working. Was fixed. Now broken.
I get the same issue. I looked up an address in the lucid app and sent it to the car from there, and it said it worked, but once I got in the car, nothing was there. Just a mess. This is really disappointing how the software actually seems to be going backwards. I’ve had the car for 14 months and the last line 3-4 have been the worst in terms of software reliability
Agreed... these last few updates have added bugs.. my car (23 AirGT) was quite stable before Lucid decided to make things more robust.
I had the same issue a couple days ago heading to an Ionna charging station.
