Oh like, like, like. An ev is not an ice car. I mean why aren’t we comparing it to a non synchro manual transmission? With the throttle it can creep in inches if you hit the “gas” just a bit. I didn’t think I would like one pedal driving but it actually works well with toodling down the road. If I’m going to get sporty then I want regen off.Just to give an alternative reality check... does it seem weird that having a car that drifts forward when you don't tell it to move seems "normal", compared to one that only moves when you press the accelerator? If ICE cars hadn't behaved this way for decades, I think we'd consider it a defect and safety hazard.
I agree or maybe mostly agree...except when I "get sporty" I really want the hard regen. I didn't think I'd like OPD either (esp when I first experienced it) but now that I'm used to it (and it certainly didn't take long) it's actually a more precise way to control such a heavy vehicle - like hard-downshifting a stick shift. YMMVOh like, like, like. An ev is not an ice car. I mean why aren’t we comparing it to a non synchro manual transmission? With the throttle it can creep in inches if you hit the “gas” just a bit. I didn’t think I would like one pedal driving but it actually works well with toodling down the road. If I’m going to get sporty then I want regen off.
You mean select it and it stays as that’s the default option setting.Roll is my preferred choice. Only need the brake to stop from 3-5 mph. Much smoother for small movement or allowing the car to glide into position. As long as they give choices. Not sure why a creep selection is not allowed to stay, roll does. Select it once and it stays selected.
Just because you don't like it doesn't make it a bad design. I don't think you'd like it if we made your 1PD hard to enable.I have to echo this sentiment. I absolutely abhor driving automatic transmissions ICEs and creep is one of the reasons why (along with bad gearing, poor gear control, no clutch, less fun, etc). Until I got a Model 3 in 2018 I only bought manual transmission cars and hated driving my wife's CVT automatic. The OP for this topic suggested creep be the default which I take as a good reason to make creep difficult to enable. We need to stop emulating bad designs that trace back to the limitations of past designs (basically, anacronisms). Calling out all the EV automakers with start/stop buttons, ACC mode, and on and on. Drove both a Bolt and Kona EVs recently and the experience is absolutely ruined by ICE-isms.
How about we just let people choose the method THEY like, not try to force our own preferences on others?
If an automaker offers something, it shouldn't be "made difficult" to enable. No matter what it is.
We get it... you despise it. Fine, don't use it.Just saying, but without data because it is impossible to have it at this point, the preference is tied to what you are used to. It doesn't mean it is a good setting, just that it is emulating what a lot of people learned on and lived with for years.
I can see the argument against some 1-pedal driving features like always slowing down and requiring a foot on the pedal to basically keep going. I just had this discussion with someone recently. They did not actually care about creep (which is the "feature", or better "bug", I despise) but rather they wanted to let their speed vary up and down hills (I kind of understand this coming from an MT) without having to hold the pedal. To each their own. But, creep... UGH... So freaking horrible. Basically the slushbox pulling the car forward to avoid stalling. In an MT the driver pushes down the clutch to prevent a stall but that control does not exist on an automatic. Auto-hold became a thing in the early 2000s but by then the damage on expectations was done.
I should make it clear. I hate automatic transmissions of all kinds from what was available when I started driving in the 90s to today's automatics and CVTs.
I get your point, the delivery was a bit more than maybe neededweird that you insist on being wrong about this. Yes, modern ICE transmissions have the capability of holding. but the dumb, inferior creep mechanic only became a thing because of limitations of automatic transmissions in the first place. Imitating this limitation in and EV is as dumb as generating fake engine noises.
I don't think any of us want the default changed. We just want it to SAVE the setting we choose.Creep might be nice to have be the default in Reverse but otherwise I'd absolutely hate having to select Hold each drive so I feel Lucid has it set up correctly for most EV drivers.
