Charging Starting and Stopping
Jmh1023
Columbus Ohio
2023 Lucid Air Pure, AWD
Since the update the car suddenly doesn’t like itself on my home charger. Our other car (Volvo) uses the same charger without any issues. Basically, the charging starts and stops every 10-20 minutes and then eventually stops altogether. When I open up the app the charging restarts again and eventually gets the car up to a full charge (80%). Lucid had me do a hard reset (no luck). My home charger is a professional install of Lucid parts and isn’t overheating and there are no loose cords etc. Has anyone else seen this?
So this is an actual Lucid wall connector? If not, some wall connectors have interaction issues with their time of day scheduling and the scheduling set up in the Lucid car. If you have scheduling turned on in either the wall connector or Lucid, you may want to turn it off and see it helps.
It is the Lucid cord that came with the car. It was professionally installed and I had no issues with it or our other car until the latest update. Now it cycles itself off and on for no apparent reason. I have not set up scheduled charging. So not sure what to do. Lucid says to try it on another charger (public EA) and see what it does before they will put it in as a service call. I was just wondering if anyone else has seen this since the update.
I am also have same issue for last 2-3 months. Finally - planning to take to service center. Only way to keep the charging going is keep the app open in front.
