- Jan 31, 2021
- Long Island
- Lucid Pure, BMW i4
- 97KPWDUB
A topic that’s gotten frequent discussion on Audi forums is the location of the charge ports. The Audi is unusual in that the upper trim levels have 2 charge ports, one on both left & right front fenders. The passenger side port is for AC charging and the driver’s side is for both high speed, DC charging, as well as an additional AC charging port. In my case it’s convenient since I pull into my garage on the right hand spot and have an easy connection to my wall-mounted charger on the right hand side wall. But that’s only AC charging.
So what’s the issue? The problem that some here may not yet have experienced (including Tesla owners), is charging at high speed, level 3 chargers. Invariably the charging cables are very short, very stiff and very heavy due to the high voltage & required liquid cooling. This necessitates inching up as close as you can (I use the Audi’s cameras to ensure I don’t hit the charging station) to minimize the required reach to the port. Even then it is most definitely a two-handed operation due to the cable’s weight & stiffness (primarily EA chargers). Whenever I used a Tesla SC for my MS, the cables were also quite short but far lighter and thinner. I needed to use only one hand.
The Lucid’s high speed port is located in essentially the same location as the Audi’s, driver’s side front fender, aft of the front tire. I’d be curious to know the actual measurement from the front of the car to the center of the charging port. I’m not sure which car, the e-Tron or the Lucid, has a longer hood. That would give us a good idea which will have a longer reach to the port.
Is this a big deal? Not really for me, a bit of a PIA, but I’ve grown accustomed to it over the years. However in reading some posts, it is a big deal for some, with several owners cursing Audi for the location of the high speed port.
