- Jan 31, 2021
- Long Island
- Tesla MY, BMW i5
- 97KPWDUB
I always take the conservative approach with cars & electronics. I operate under the assumption that the product I buy today is the way it will be for its lifetime. If I’m fine with its current performance, then any improvements will put me in the bonus round. If I purchase operating under the assumption that although I’m not fully satisfied today, there will probably be firmware upgrades in the future that will make me happy, then I’m simply gambling. If those updates don’t ever materialize, I will probably always be less than satisfied. There is also the issue of how long any improvements take to be implemented. Conservative companies can take the cautious approach and I suspect Lucid falls into that category.The charge rate today isn't the rate you may see tomorrow. Kyle stated that Lucid engineers told him they would start with a conservative charge curve then ramp up The number to look for depends on where you are on the curve. Seems like every EV has a different charge curve designed for it...and manufacturers change the curve as they get more comfortable with how the vehicles are performing via OTA update. Lucid might go the Taycan route and be aggressive to 50% then taper off. They will probably charge the test cars every night and depending on demand, limit test drive duration.
On your cross country trip, you will also run into EA stations where they haven't upgraded to 350 and are still at 150 so be prepared for longer waits to charge since you might want to charge to 90 - 100% for some legs. Depending on the curve, it could take 2 to 3 times as long to get from 70% to 100% as it took to get from 20% to 70%.
Obviously this is all dependent upon the magnitude of the issue that initially bothers me.
