CarPlay quit working after 2.6.16 software update
danabu
Redlands, CA
Lucid Air GT, Tesla Y
My iPhone 16 iOS 18.4.1 was connecting via CarPlay to my 2022 Air GT just fine prior to the recent update, but now after updating the car I can't get CarPlay to work again. I've rebooted the car, rebooted the phone, removed it, re-added it. Sometimes the phone comes up asking if I want to do CarPlay, and I say yes, but I just get a spinning circle on the car that eventually times out. The audio will play as a Bluetooth device, but not as CarPlay. Has anyone else had this issue and found a solution?
Is your WiFi on the iPhone turned on? It needs to be in order to connect to CarPlay. That might be it.
When you removed and re-added, did you remove the car from the phone AND the phone from the car?
Thanks for the replies. Yes, WiFi on the phone is enabled. And yes, I deleted the car from the phone, and the phone from the car. The phone does seem to remember the custom name I assigned when I reconnect the car, so maybe there’s a way to more fully remove it… I’ll look for that.
On your phone, go to settings and then Bluetooth. Locate the entry that is entitled "Lucid Air XXX." Tap the info button and then choose "forget this device". After that, hard restart your phone. (The one entitled Lucid -XXXXX" is mobile key and not necessary to remove.)
I restarted my phone after removing the car from BT. No difference when I reconnected - the car and phone make a BT connection successfully, but not CarPlay.
Perhaps related - I couldn't get CarPlay to work when I connected a physical cable, either. The phone starts charging, but there's no recognition of it as a CarPlay device by the car.
The hard reset of the phone is what fixed this issue for me. Good call.
An update - after multiple times removing, readding, restarting, I finally got things to pair successfully again. I think this is finally what did it:
  • Removed the phone from the car
  • Remove the car from the phone
  • Stopped and restarted bluetooth on both devices
  • Rebooted the infotainment system on the car
  • Powered down the phone and powered it back on
I thought I had done all these steps before, but maybe not both sides completely at the same time.
I had a similar problem and I could not figure it out, however, after some time, it just seemed to suddenly start working. However, now that I think about it perhaps rebooting the phone helped. The weird thing for me was it first started working on wired only and for the next 10 to 15 trips only wired would work, and then suddenly wireless worked. Now it has been flawless, working both wired and wirelessly. Definitely the most stable CarPlay has been since I got the car.
This is always been the solution. I made a video about this two years ago and nothing has changed!
