CarPlay and Lucid Assistant - can both be active at same time?
NLH
Lucid Air Touring 2025
If CarPlay is active, pressing the microphone button activates Siri. Is Lucid Assistant inactivated in that scenario? If yes, then how does one inactivate CarPlay so the microphone icon activates lucid Assistant?
Another question: besides using the words “navigate to…” what other commands work to activate Lucid Assistant navigation?
Weird. It only activates Lucid Assistant for me even when CarPlay is connected
I call them, Hey Lucid for Lucid and hey Siri when needing siri. Not sure if its Lucid, when i said hey Siri it respond back saying i am Lucid’s assistance you can say hey Siri to apple.
Long press for Siri and short press for hey Lucid.
I just tested it myself:
To talk to Siri, with CarPlay active, say Hey Siri. Pressing the microphone button is not necessary. I didn’t test a long press to confirm it activates Siri. A short press activates the Lucid Assistant even with CarPlay active.
Even with CarPlay active you can say Hey Lucid or short press the microphone button (without saying Hey Lucid) and you will see “Listening” on the top right panel and speak a command or ask a question and the Lucid Assistant will respond.
For Lucid Assistant navigation: You can ask Lucid Assistant to “navigate to ….” and it will do it. You can also say things like “go to… “ or “route to … “, and Lucid Assistant will respond.
To shut off CarPlay, you need to go into Settings, to Connectivity and press the CarPlay arrow in a circle icon to shut it off. To turn it back on press it again.
