- Jun 17, 2025
- 2025 Air Touring
New owner, first post, I have several things to post but will start here.
When using ACC in the city it all works pretty
great with one big exception. When approaching a car stopped ahead in your lane (usually at a red light, traveling reasonably fast 50-55 mph) it takes much too long for the ACC to pick up the stopped car and start applying the brakes. If you have nerves of steel, you can wait and it will stop, usually very aggressively, but it is really hard to have those nerves.
It is particularly bad when it is 2 or 3 lanes wide and your lane has less cars than the other two. You end up screaming past the cars on the left or right before ACC applies the brakes.
It does appear there is a correlation between the 3D visual traffic display showing the vehicle and the awareness there is a car stopped. So the limitation is either the lidar/radar distance sensor range or the software just not reacting fast enough to the stopped car. Hopefully the latter and it can be adjusted.
