Android Auto in 2.7.0 - Initial Impressions
At night, Android Auto seems to want to stay in day mode which makes the screen very bright while driving. I had to switch back to the Lucid maps so that I could drive without my eyes hurting. Does anyone else have this problem? I can't seem to find a setting to enable night mode to darken the layout at night, but on all my other cars, Android auto switches automatically based on exterior lighting.
Lucid's implementation may be incomplete, or have a bug.
This is strange, as mine works perfect from the first time I connected AA. Even when I drive through short tunnels it switches to dark mode and switches back when I exit. On Pixel 7 with Android 16.
Are you talking about the AA screen itself, Google Maps, Waze, etc? What phone model and Android version are you on?
I also had no problem with the day/night setting. In fact I turned it on Night mode only because of exactly what @Genghis said, was a little trigger happy swapping when I drove thru an underpass/etc.
I think he probably didn't notice the setting at all, but it's there!
Look at your AA settings to see if it's set on Day Mode only
Google maps. I have a Pixel 9 Pro XL on Android 16. I have the same setting as you where it's supposed to flip back and forth between night/day based on lighting. I'll keep testing, but last night when I was driving it wouldn't come out of day mode.
You are not alone. Same issue on my Pixel 9 Pro with the setting set to Automatic. It never switched to night mode automatically for me. I have another car (Ioniq 5) where the automatic day/night switching work great through Android Auto. On the Ioniq 5, my best guess is it's based on the headlights being on/off which reports it back to AA. Haven't had much time to mess around yet to try to find a fix.
I noted that when I changed WAZE to night mode then google maps also switched to night mode automatically.
Overall very happy. Some initial thoughts after a few hours of using it ('25 AT). What are your thoughts?
Things I like:
1. That it will auto start if desired when I get in the car and that there's so much flexibility in moving back and forth between AA and native apps. I thought I would use it in more of al "all or nothing" approach (e.g. always yes or not) but I can see how I might use it sometimes and not others, or may move in an out of it during a drive as needed. And, so far, it has no issues with me jumping in / out of it. That was a nice surprise. And overall, I really enjoy the integration of AA to the car's physical controls (buttons, etc). I know that's expected but I am really glad it's working and how it was done (as expected!).
1a. Learned a little trick that if I am not in AA and I long press the mic button to get Google assistant, it will open AA on my car display and interact (and stay open after the voice part is done). Easy way while driving to launch AA (I think!!). Love that I can easily access google assistant by voice via the button.
2. That the car will display the audio track and navigation next turns on the driver display even if it's coming from AA. That's pretty cool and unexpected by me (I had never seen carplay in use in the Lucid). This is great so if I want to have the map take the full AA display, I can still see the audio track. And of course I can see next turns even if I have something else running in AA.
3. That I can still use the car's native audio apps, especially Tidal, when using AA. Wasn't sure if that would be enabled .. it's available on my wife's older BMW with carplay but had no idea what would happen in the Lucid with AA.
Things I am getting used to:
1. Since AA is grabbing my phone's wifi, and the cell signal in my driveway is weak, I find my phone is disconnected from my house wifi when I get into the car. So if I need to plan on google maps on my phone or do something else, I might have to manually connect to my house wifi again. Will have to figure out the flow on this one.
Things I hope can be improved at some point:
1. Would love higher quality audio stream from phone to AA .. I think it's 44.1khz 16 bit (undetermined bitrate) but would love higher quality from the phone youtube music app.
2. Would really like the google map EV features available in Android Automotive (AAOS) version of google maps .. SOC at destination (with amazing accuracy), auto selection of charging stops, and automatic battery pre-conditioning if a L3 charger is the map destination. Unfortunately, even though my profile in google maps on my phone knows that my car is a Lucid, it shows only eco info etc. The AA google maps doesn't calculate charging stops or show SOC at destination. This makes me think that I'll use native maps for longer trips and google maps for non-charge trips, or some back and forth. I'm still doing route verification in google maps before a trip because I think it has slightly better data than the native here maps. and search in the native app is really not good. I also have paid ABRP so that's the best of both .. mapping in AA with charge stops planned. But I think I still trust google maps route calculation more (will have to play with that as I haven't used ABRP much) and also I think the use experience is great (turns overlayed over music app if the music app is taking full screen, etc). I tested and can see the car will only allow one mapping app to run at a time and the last one with the route started is the one that takes precedence and nav in the other is cancelled. Would love additional thoughts on this one and approaches to getting the best of all the mapping apps.
Not much commentary on the screen real estate .. I think everyone wishes it could use more and it's just not how it works with Google, so not a lot to say. I like that my wallpaper theme is used for the background color.
Took a long time, but THANK YOU LUCID TEAM!! (I've only had my car since Dec '24 so not that long for me 🤣)
AA is flexible, Lucid did a nice job giving most of us all we could ever expect. I am pleased.
A+ tip, long press works and yes AA will ask you to reply without any additional inputs.
I'm glad AA can be used to fill this gap, it was crazy the number of steps Lucid made you do to reply to a message!
"Hey Google" just works for almost all simple functions. No presses needed :-).
I have a Samsung S24 & I'm having 2 issues with AA:
1. Every time I get in the car I have to manually hit the AA button on the home screen to launch it despite having the toggle set to have it start automatically
2. AA always fails to load the first time I launch it from the home screen, including an AA error message on my phone, & then launches successfully when I launch a 2nd time
Anyone else having these issues and/or has successfully addressed them?
This might not belong here, but @Denali_Dane and I just experience Android Auto in a Subaru and can confirm it’s way worse, way slower, less responsive to inputs, and extremely buggy on our friends newer model Subaru.
Just to contrast this AA is working well and reliably (if not turning on automaticity for @Denali_Dane ) at least boooting up after a few seconds. Or tapping of the devices screen.
Yep its true, I saw it with my own eyes from the back seat.
