- May 20, 2024
- Northern NJ
- 22 Air GT, Honda S2K AP1
- TGR2P9J7
None of the discussions about range and miles per kwh appear to take into account the density of the air. Simply put, doing 70mph in calm winds near sea level is going to require more power to push the air out of the way than it would to drive at 70mph at 5300ft above sea level.
I say this because the efficiency numbers you're going to see from people driving in Denver/Boulder in the summer SHOULD be considerably higher than people driving at sea level under otherwise similar circumstances.
Pilots of aircraft deal with the implications of low vs high altitude flight on a daily basis...it's absolutely a thing. It's also why if you look at the airspeed indicator on an airplane flying at 35,000ft, it might read, say, "280", but that actual speed through the air is more like 430.
Another way to look at it is that, linear increases in rolling friction aside, you should be able to drive considerably faster at 5300ft (even more so on a warm day) with the same power output from the power plant as compared to the same setup at sea level.
