- Jan 2, 2022
- Fort Lauderdale, FL.
- Lucid DE, Plaid, Rivian
- Air DE Number
- 180
I was surprised to see Kyle did not test the Rivian using the conserve mode. In my experience the conserve mode delivers 10-15% better m/kWh.Kyle Connor on Out of Spec motoring recently did an efficiency test on a Rivian R1T with an empty bed and then with a giant water tank filled to the maximum towing capacity the vehicle has. The unweighted truck got 2.1 mi/kWh, the weighted one got 2.0 mi/kWh. This strongly suggests aerodynamics is the biggest contributor to range and weight only has a marginal impact. I think pulling an empty much lighter trailer behind the R1T much more dramatically reduces range. So I’d be surprised if weight had much impact on the Lucid unless it’s a LOT.
