Im confused by what you mean, do you mean the battery on the AGT ran out?I’ve been having construction done and the charger got disconnected and my AGT is dead. If I plug it in to the charger will it do any good?
First, I would make sure that you can charge it absolutely as soon as possible. A battery staying at or close to zero for an extended period of time is very bad for it.Yes - the charger was disconnected and we got back and the app shows 0%
It has no power so I cannot open it
Call. Service.The charger has been plugged in and still is. The breaker was off. The charger is back up and flashing like it is charging but it doesn’t seem to be doing anything. Is there a way to charge the 12V battery and would that help to get the car to charge?
If it’s actaully in the manual, I’d say its fair game!I agree with with wait for service but I found this on the internet... use AT YOUR OWN RISK!.
Charging The Vehicle; Disconnecting The Charging Cable - Lucid Air Owner's Manual [Page 145]
Lucid Air Manual Online: charging the vehicle, Disconnecting The Charging Cable. Plug The Charging Cable Into The Charge Port. High-Voltage Battery Pack & Charging Note: During Charging, The Battery System's Heating And Cooling Functions Monitor The Temperature Of The Battery Pack,...www.manualslib.com
"Manually opening the door
CAUTION: Manually opening the charge
port door is only recommended in
instances where the vehicle has no
power and the 12V batteries cannot be
charged.
If the vehicle has no power, the charge port
door can be opened manually:
1. Open the driver's door.
2. Place your finger at the bottom right
corner of the charge port door and gently
lift up.
3. Continue lifting on the corner until a gap
begins to form between the top edge and
the fender.
4. Once there is a gap along the top edge,
insert your fingers into the gap and
gently pull downward until a hard stop is
reached."
I think they all look like that , except for cars used in marketing materials.Now I know why my charge port door is misaligned. Looks like someone was trying to pry their fingers into the bottom right corner gap...
No, it isnt likely that's the reason. The charge port door being misaligned is a common issue as you press it every time you want to open it. I would ask mobile service to realign, it is a very small job!Now I know why my charge port door is misaligned. Looks like someone was trying to pry their fingers into the bottom right corner gap...
I thought Cosmo was just joking...No, it isnt likely that's the reason. The charge port door being misaligned is a common issue as you press it every time you want to open it. I would ask mobile service to realign, it is a very small job!
If he was, sorry for the misunderstanding lolI thought Cosmo was just joking...
