A good way to check battery health?
Try charging your car to 100% overnight, and see what range the car says in the morning compared to its EPA range.
It's possible that the pack may have become unbalanced if you haven't charged it to 100% in a while.
There is no need to charge to 100%. A quick way to get ballpark battery degradation is by using the following formula:
  • current_rated_range / current_SOC / EPA_range.
For example, for my Gravity:
  • current_rated_range: 134 miles
  • current_SOC: 32%
  • EPA_range: 420 (GDE, 7-seater, 20/21 inch wheels).
My battery health is 100%, taking into account that the SOC is only 2 significant digits.
  • 134 / 0.32 / 420 = 0.997 (1.0 after rounding to two significant digits).
The hardest part is getting the correct EPA range that is programmed into your vehicle, as that will vary by tire size, trim, model, etc. For the GGT EPA, I’ve seen (may be wrong):
  • 5-seater small wheels: 450
  • 5-seater medium/large wheels: 407 (I’m not very confident in this number)
  • 7-seater small wheels: 437
  • 7-seater medium/large wheels: 386
The other values can be found in your car. For example, my numbers were from:
There is no need to charge to 100%. A quick way to get ballpark battery degradation is by using the following formula:...
Understood - my suggestion of charging to 100% overnight was to allow the BMS to balance the cells at the top end. It's possible that the observed drop in SOH was just a side effect of a cell imbalance.
I'll try that. Thanks.
A few questions:
  1. Is there anything in your manual that suggests charging to 100% for battery health? Typically for your battery chemistry, NMC I believe, that doesn’t do what some LFP batteries do which is balance the cells for your BMS and a 100% charge can be recommended weekly. But you don’t have a LFP battery. Can you screenshot anything from Lucid that says charge your NMC battery to 100%?
  2. How can you use battery SoC to “reverse engineer” a battery SoH percentage? Aren’t your range readings based on algorithms that are guessing range based on driving habits, tire wear, load etc.? I don’t think there’s a formula for SoH. It just is what it says, if you can find it.
  3. Does anyone have a screenshot of their current SoH? If so how did you get there?
  4. I highly doubt anyone has a battery health of 100% unless the car is brand new. Also, NMC batteries are built for performance and range so they lose more battery health early before settling in and then with good management you should be good until 84% but that’s not a number you can get unless you’re a Lucid tech. Isn’t that correct?
  5. Is there a Lucid tech on here that can confirm or deny the Lucid screenshot that says “Display the current SoC as a percentage of battery health” is not the real number but that techs can see the real number?
  6. What OEM tools do you use to get S0H, pack and cell health? Are their physical port readers or is it all OEM through the cloud?
We have the Lucid and also the Genesis GV60. For the GV60 they do recommend charging to 100% once a month or so to maintain good battery health. That said I don't know if the GV60 has an NMC battery or the LFP. To be honest we have not been charging it to 100% every month. When we had the "free" EA Charging for the first three years we did leave it on the charger for the full allowed 30 minutes and that would often charge it up to mid to high 90's SOC each time. Since that program has elapsed I charge it to 80% at home except when we are taking a long trip. I do the same for the Lucid but again only to 100% when going on a long trip. The Lucid still shows 420 miles when charged to 100% but I know that is not correct at 75 mph on the freeway.
A few questions:
Lucid does not directly give us SoH in the car, but it’s in the telemetry. See the second post on this thread for the community developed API, which can be used to reverse engineer and/or validate the SoH.
For the Gravity, the SoH field is 0, but we can calculate it from the other stats (see stats that I pulled). It gives current SOC (both % charge and kWh), so we can calculate the total usable capacity at 100% charge. We can compare this to the original usable capacity (also given) to calculate SoH.
Although we can’t see battery energy in kWh from the in-car displays, we can substitute rated range (not dynamic range) for energy when calculating battery SoH. As an example for my GDE, when new, 117.39 kWh = 420 miles from the telemetry. When battery health goes down, 100% charge will show less than 420 miles of rated range. Yes, we are assuming miles/kWh remains constant, but it would be silly if that changes over time instead of the amount of energy the battery pack can hold.
How can the battery health stay at 100% after owning the EV for a while? The health (and range) is based on the usable capacity instead of battery pack size. There is a buffer between usable and pack size, and the initial battery degradation eats into this buffer. In the Gravity’s case usable is 117.39 kWh vs. a pack size of 123 kWh. At some point, the degradation will be high enough that the pack can no longer charge to 117.39 kWh and we’ll start to see SoH decreasing.
As far as charging to 100% to rebalance cells for Lucid EV batteries (NMC), I can’t find a Lucid official source that recommends it. However, I have seen charging stall at 99% for a long period of time, which is characteristic of the BMS doing balancing. I’ll have to monitor the 99% charge rate as mentioned in EV world on battery cell balancing. Does anyone know for sure?
Here is my battery degradation in five months since brand new:
Field 11, battery_health_level: 97.50000145286322
After 40 months, and 13,462 miles
Field 11, battery_health_level: 97.00000144541264
I own both a AGT and a Gravity. They use the same login. There's only one Field 11 for Battery Health. Which vehicle is it for? And how do I get it to show both vehicles?
It should show all vehicles on your account. I only have the one so I can't check right now, but I have seen it work for other people. Can you share your whole result?
My guess is that that you’ll see multiple data sets, one for each vehicle. I only have one Lucid, so I can’t verify.
