- Apr 30, 2023
- Lucid Grand Touring
- WDATGN78
I will post the 90k+ ODO, 95% charged on DC fast chargers exclusively, 100% charge picture here for those worried about degradation. 2022 AGT.
Ok, well, I’m taking a chance since I still need to set up Home Assistant and I want a baseline before driving more miles. Nice job reverse engineering the API. I submitted my info, although I'd recommend redacting the nickname and charging subscription information.Sure. The Python bindings are open source, as is the Home Assistant integration.
I totally understand not trusting me or @segbrk, and you are more than welcome to make the API calls yourself or use HA.
But for what it’s worth, your credentials are never stored, so they cannot be stolen. The results of your API call are shown to you and then *only* get stored, encrypted, if you hit the button allowing it to be shared (so we can build out the API).
But yeah, there’s no pressure whatsoever to use it. Just a public service.
"vehicleState": {
"batteryState": {
"range": 305,
"chargePercent": 45.10000067204237,
"kwHr": 52.959998816251755,
"capacityKwHr": 117.38999737612903,
"unavailableChargePercent": 0,
"batteryHealthLevel": 0,
"chassisState": {
"odometer": 2260.1000336781144,
With buffer, yes, that is correct. Usable air battery (gt and above) is around 110kwhOk, well, I’m taking a chance since I still need to set up Home Assistant and I want a baseline before driving more miles. Nice job reverse engineering the API. I submitted my info, although I'd recommend redacting the nickname and charging subscription information.
Battery health isn’t in the gRPC output (Field 11 is missing), but in the JSON output, I do see batteryHealthLevel.
GDE, 20/21 (Voyager) wheels, 7-seater, odometer 1404.361 mi (2260.100 km).
JSON:"vehicleState": { "batteryState": { "range": 305, "chargePercent": 45.10000067204237, "kwHr": 52.959998816251755, "capacityKwHr": 117.38999737612903, "unavailableChargePercent": 0, "batteryHealthLevel": 0, }, "chassisState": { "odometer": 2260.1000336781144, },
Does this mean the health is 100% with a usable capacity of 117.39 kwHr?
All gravity battery health sits at 0 right now. I assume they haven’t updated that field.Ok, well, I’m taking a chance since I still need to set up Home Assistant and I want a baseline before driving more miles. Nice job reverse engineering the API. I submitted my info, although I'd recommend redacting the nickname and charging subscription information.
If I understand correctly if your battery was charged to 100% you would have 83.68kwhr available now. So a loss of about 9%. I just had a new GT battery installed in my 2022 because of HV battery failure and the one they installed has a 10.7% loss off the 112 kwhr it should have. Lucid service says this normal and we should expect a 2-3% loss in battery capacity every year.Hoping someone here can help me understand if there is something wrong with my HV battery. I have a 2023 AT with 34k miles, I should have a 92kwhr battery pack. The API reporting capacity_kwhr: 83.68 and battery_health_level: 95%. If there is a 5% degredation on my 92kwhr battery, shouldn't I see my capacity to be at 87.4%? In my real life driving, I saw 24 kwhr used with 30% usage of the battery, which equates to 80kwhr total battery capacity. I spoke to Lucid Service center and they insisted that everything is normal but the math isn't mathing.
While the 92 kWh is the battery pack size, usable is less than that. Some capacity is reserved as buffer and there are probably other fudge factors.Hoping someone here can help me understand if there is something wrong with my HV battery. I have a 2023 AT with 34k miles, I should have a 92kwhr battery pack. The API reporting capacity_kwhr: 83.68 and battery_health_level: 95%. If there is a 5% degredation on my 92kwhr battery, shouldn't I see my capacity to be at 87.4%? In my real life driving, I saw 24 kwhr used with 30% usage of the battery, which equates to 80kwhr total battery capacity. I spoke to Lucid Service center and they insisted that everything is normal but the math isn't mathing.
Has the location for this utility changed in the past year? I tried the link and it dead-ended. I just charged my '23 AGT to 100%. Based on the guess-o-meter reading I have 503 miles range, which equates to 97.5% of the EPA rating of 516 for a '23 AGT. I know the guess-o-meter is not an appropriate gauge for battery health, but it's all I got unless / until I can access the utility.
It's still there and working for me. What do you see?Has the location for this utility changed in the past year? I tried the link and it dead-ended. I just charged my '23 AGT to 100%. Based on the guess-o-meter reading I have 503 miles range, which equates to 97.5% of the EPA rating of 516 for a '23 AGT. I know the guess-o-meter is not an appropriate gauge for battery health, but it's all I got unless / until I can access the utility.
Usable is not the rated capacity. Your newer Gravity matches mine: 117.39 kWh usable (not 123 kWh)..
I'm a bit surprised/worried/disappointed in the degradation of the Air battery. Less so for the Gravities at this point, given that there is usually a quick degradation for a short while after a battery pack goes into service . . . and there is some confusion about whether it even started with 123 kWh usable or something more like the 118 kWh Conner claims.
Your Air gives health directly: 93.0% (backward calculating, 112.4 kWh usable at 100% health).
Your Gravities are at 100% and 99.31%.
another data point -- 2025 Air GT 22,000 miles delivered 9/2024 Battery at 97% capacity 110 kWh.![]()
now, after 22,000 miles. I didnt know about this great resource at delivery.97% at delivery or now?
