- Jan 20, 2022
- Mount Prospect, IL
- 2023 Lucid Air Pure AWD
- KDGO18C2
Also, if your theory were correct, I probably wouldn’t be able to drive other vehicles without experiencing the symptoms. But I can.
Am I safe to assume you would get just as ill being in the passenger seat having someone else drive your Lucid?
So you mentioned a Model 3 not making you sick. Was it an AWD model 3 or RWD (just curious)? Also, were you able to drive it for a prolonged period or only in it a short amount of time equivalent to your prior Lucid test drive?
Do you have anyone else (friend or family) that could drive your Lucid for as long as it normally takes for you to get sick and see if it affects them as well? If there is perhaps somehow some shielding that wasn't installed correctly or forgotten, I would expect more people would encounter the same ill effects. (its my theory anyway).
That's my thoughts anyway.
I've had my AWD Lucid since July 2023 (a 2023 model) and have had none of the issues you speak of (not as a driver or passenger including on a 4000 mile trip where I didn't drive 2000 of the miles since we shared the driving). I would wonder if you would experience the same thing in my Lucid for example. Would I experience the same issues as you in yours? I have no idea where you are in the country but the idea of a loaner Lucid already mentioned to see if you encounter the same issue seems reasonable to me because if you do not, THEN I'd start to question shielding in yours during assembly (especially if prolonged driving in yours by others yield the same negative results).
