Also holy crap. Your app used 1.72GB of data since May 1? What in the world?!?!I just spotted that the mobile app on Android is 27GB. Seems awfully big for what it does. Can anyone else confirm the size on their phone?
And if anyone is interested in downgrading given this version seems to have serious issues (battery drain, and now add storage bloat and data utilization)Wow. Mine is at 604mb but I just installed yesterday after downgrading to may 1st 2.4.0 APK in order to deal with the battery leak.
Hi Pyle112,And if anyone is interested in downgrading given this version seems to have serious issues (battery drain, and now add storage bloat and data utilization)
To the extent helpful- I take no blame for installing apps outside app store- but for informational purposes, here is how one could downgrade once the app is uninstalled:
I downloaded the may 1st APK from here:
https://apkpure.com/lucid/com.lucidmotors.mobile.prod/versions
It's packaged as an xapk so you'll need to unpack and install with an installer- I used the most popular one here:
XAPK Installer - Apps on Google Play
Hope this helps!
Adding @marqie for awareness and guidance
Uninstall the app. Install the downgrade. Re-pair mobile key (should recognize the phone, no need to delete mobile key from car)Hi Pyle112,
Would I have to repair the phone to the car after the downgrade? I'm assuming I have to uninstall the current before installing the older one correct?
Thanks
App: 271 MBMine is at 2.29GB Total. Can you check the App Size versus User Data Versus Cache?
Mine is 255MB App, 1.60GB User, 438MB Cache.
It might be worthwhile to clear storage which will trigger the user data to wipe. Then you can log back in and it'll clean itself up.
Yes, this is because I had previously set the Lucid app to ONLY use data via mobile network. It used to be workaround for me to be able to wake up the car very fast at home versus when I'm on home network. I reverted it back to normal just recently.Also holy crap. Your app used 1.72GB of data since May 1? What in the world?!?!
When you say battery leak, are you referring to how the car is almost always awake? If so, I definitely have this problem. I'm going to try installing the version from 2 updates ago since it used to be very responsive at waking up the car.Wow. Mine is at 604mb but I just installed yesterday after downgrading to may 1st 2.4.0 APK in order to deal with the battery leak.
Thanks. That worked.Uninstall the app. Install the downgrade. Re-pair mobile key (should recognize the phone, no need to delete mobile key from car)
So far so good. I'll report back tomorrow morningHas anyone kept 2 4.1 open, and verified that it's not keeping the car awake and draining the battery? I installed 2.4.1 but force stopped and closed the app.
