- Nov 19, 2021
- Cupertino, CA
- Air DE-P, Gravity DE
- Air DE Number
- 241
- Gravity DE Number
- 013
- Q1BTN5Y3
Those clips break basically every time you take that cover off, but I’ve never heard a knocking noise from it. Fascinating.I have my car back, and took a photo of the culprit element. It was replaced and everything sounds good so far. Photo attached, with my finger over the replaced part. It’s only part of the whole drape assembly. I (poorly) traced a yellow line along the edges.
On the underside, there are thin rib / filaments that run across which were bent / warped, and the technician also though the whole component had too much flex in the plastic.
Hope that helps, in case anyone else is facing a similar problem.
Sidebar: Separately, the technicians applied sound dampening butyl tape to improve car audio. I thought I’d read in a few places here that this was a pre-requisite to firmware upgrade I’ve already received. I asked my Lucid Service contact, and she said tape was not a pre-requisite, and they just apply as needed on service calls. Based upon other people’s reports here, it appears to me like some vehicles must have the tape before the upgrade, and others can be upgraded without it. I’m not sure what sets the distinction.
Tagging: @vav493 @segbrk @lucidtouringman
Did they apply the tape to the footwells or the tweeters (upper speakers)? Also, do you have SS Pro or regular?
