Problem with Gravity Rear Hatch
hmp10
Founding Member
Naples, FL
Air DE-P, 2 Gravity DEs
Air DE Number
395
Gravity DE Number
067
238
033M4EXG
The rear hatch on one of our Gravities no longer raises to full opening height. We have tried to push it manually up to full height in order to use the fob to reset the height adjustment, as instructed, but the hatch will not move. (We have another Gravity for comparison so know this one is no longer opening fully. Short by just over a foot, in fact.)
Any suggestions?
From the user manual:
Liftgate Height Adjustment
1. Manually move the liftgate to the
desired position.
2. Press and hold the liftgate button
on the lower edge of the liftgate
for 3 seconds. When the hazard
light flashes, the liftgate position is
saved.
The liftgate will always open to the
saved position until a new position
is saved.
desired position.
saved.
is saved.
Yes, we tried this. The problem is that the hatch can't be manually moved to the fully-open position. We have both tried to push on it simultaneously.
It sounds like a service call, unless customer care has additional info.
I'm sure you have checked, but no externally visible parts stopping? Panel getting in the way, etc.?
Sorry to be asking, but it certainly sounds like a mechanical stop as opposed to software. Physically pushing should be able to override any little actuator assembly.
Yeah, this. When our lift gate motor stops (because we stop it) we can manually move it just fine.
Service :/
Service :/
Yep. The hatch sometimes stops halfway up on our other Gravity, and we can always push it up manually the rest of the way. But since a reboot fixes it, I assume that's a software problem. But on this Gravity, the hatch won't budge no matter how hard you push. And reboots don't fix it.
We've also opened the hatch using the app and using the icon on the Pilot Screen. But it always stops short of fully open.
My partner was leaving a tennis match and carrying his gear when this first occurred. He came home with a bump and blood on his forehead. He uses the rear hatch frequently and didn't notice it had not opened quite all the way.
The car is being trucked over to the Miami Service Center tomorrow. They said it's rare, but they have seen this with a few Gravities.
Thanks again for being that 1/million, whoops 1/100,000 no 1/10,000 so mine won't get it! Oh I meant to tell you a while back that I read global warming has caused the Bermuda Triangle curse to shift west.
