OTA 3.6.4
I made it from SF to SoCal on Thursday and handsfree did a stellar job almost the entire way. There were only a couple of places where I had to take over and a small stretch that didn't allow handsfree and no cases where the "can't see you" warning light was showing...
We're seeing 2 undesirable things after the 3.6.4 update:
- Park Assist pops up EVERY time I stop. Traffic light, stop sign etc. I turned off everything related to Park Assist.​
- The fan noise for the ACC see much, much louder. Changing to manual and reducing the fan speed down to 1 or 2 does not reduce the fan noise. It's difficult to have a conversation.​
Curious to hear if others have seen either of these symptoms.
Thx
Thx
Have you verified your back seat ac is off or synced to front? Often, that's the issue. The back ac is running on auto or full speed and the front is running low and the noise is tremendous.
Thx
no & no (at least right now)
Not really. Our AC seemed a little louder than normal today, but not so much as to inhibit conversation.
Thanks @DeaneG . I'll check that, do believe the rear AC was still on.
When we have passengers in the second row (or third), they're going to want that AC!
Can confirm that when the rear HVAC fans are set say above 4 that it's annoyingly loud in the driver compartment and need to be turned down
I try to keep them all at fan speed 4, or even 3. HVAC fans are loud in the normally quiet Gravity. I keep the rear vents on all the time, as it helps to cool the cabin faster with less noise.
My 3.6.4 bug is with the Homelink software. When I go to my sister's house, I get prompts to open her garage doors instead of mine. When I come home from her house, I sometimes (usually) still have here garage door prompts and not my own. We initially fixed this my rebooting the car. My wife later discovered that if you put the car in reverse and then back into drive Homelink will list all programmed garage doors for opening/closing. Note that geofencing between her house and mine used to work before the latest update.
fyi - Showing that full list of all programmed doors is pretty normal when we are first backing out of our garage. I've assumed it's because it doesn't have a GPS signal yet. Maybe having Homelink display the full list when backing up is a software workaround already programmed in for that. It would explain why my wife's workaround works.
I got so sick of the Homelink issue I removed my other Homelink devices, now with only my house on Homelink I'm enjoying being able to use the custom button on the steering wheel. Although with your workaround I may add the other Homelink devices back
Yes! That’s it!
I turned off the rear entirely and the fan noise in the front got noticeably quieter. Not sure how or why but that’s the answer.
It solves the noise issue until we have passengers in the back. ;)
Yes! That’s it!
I was actually just commenting to my wife today that that is our only complaint about the Gravity heh
...I turned off the rear entirely and the fan noise in the front got noticeably quieter. Not sure how or why but that’s the answer...
This got me a few days ago as well.
In the Air, rear automatically turned itself off when you had no rear passengers. I was surprised Gravity always seems to turn the rear on, even if I turned it off last time and there are no rear passengers.
I had to set the fans to 1 back there, and then it is both quiet and stays that way.
