- Jul 14, 2025
- Denver, NC
- Air GT
- CVUA5DWW
I have heard that wrapping in foil may act as an antennae, Just buy a faraday bag. Works greatI had similar issue. It is a common complaint I believe. Either you should keep the Key fob at least 25 feet away or put it in a metal box or wrap it up in a tin foil, with that the two way communication is prevented and the battery does not dry out.
