Lucid Air Software Updates for Europe
toblin
Aarau, Switzerland
Lucid Air Touring 2025
Since European Lucid cars are on a separate update track, I am starting a new thread to post the new Over-The-Air (OTA) software releases for the Lucid Air. I happily remove this one again if lucidupdates.com starts covering these.
Lucid Air Firmware 4.7.2 - 30.07.2025
Overview
  • Android Auto TM
  • DreamDrive Pro
  • Intotainment
  • Drivetrain
  • Soft-close Doors
  • Sapphire
Android Auto
Android Auto integration is now available and allows seamless integration of AndroidM phones with the Lucid Air's Glass Cockpit. Android Auto is available both wirelessly and via USB. Android 9 or higher is required for a USB connection, and Android 11 or higher for a wireless connection.
To use Android Auto with an Android phone that is already paired with your Lucid Air, go to Settings > Connectivity > Devices and make sure the Android Auto icon next to the name of the phone you want to use is gold. If not, tap it to enable Android Auto.
You can then launch Android Auto from the Right Cockpit Panel by tapping the Android Auto button. If the icon does not appear, try deleting and re-pairing the device, then confirm the prompt to launch Android Auto
Note - Android and Android Auto are trademarks of Google LLC. Compatible Android phone and compatible active data plan required
DreamDrive Pro
We improved the lane centring function to maintain set speeds in curves without reducing speed.
Adaptive cruise control (ACC) now automatically resumes more easily in stop-and-go traffic.
Infotainment
We improved Bluetooth device connectivity. Note: Some cars may need to turn Bluetooth back on after this update.
Settings > Connectivity > Devices.
We improved the radio listening experience. You can now switch stations more smoothly and avoid the "no audio" issue after entering the vehicle.
Sapphire
New electronic damper tuning for improved vehicle ride & handling experience
It seems like Drive Assist now works on "Bundesstraßen" with 2 lanes. At least on B30 / South Germany it works now.
Max speed of drive assist is not 147kph - maybe this is a (new) rounding issue or casting to integer.
Didn't it work with you before? For me it worked quite reliably also before the update. But after the update I do notice an impressive improvement of Drive Assist.
I get the same.
Before update 2.7.2, it would do drive assist at 150 km/h, but drive assist would freeze when passing other cars at 150 km/h. It was fine at 140 km/h. Maybe 147 km/h was set as a limit so that the car does not go above 150 km/h even for a brief moment when going downhill, which might have been related to the drive assist freeze. Just a wild guess.
