- Mar 7, 2020
- Naples, FL
- Model S Plaid, Odyssey
- Air DE Number
- 154
- 033M4EXG
Wanna see what's under the frunk liner in your Gravity?
Our Gravity DE finally made it from the PPF installer to the radar installer, where we're having a Uniden R9w radar/laser detector installed. Should get the car home tomorrow afternoon and finally have it to really check things out.
The Uniden control unit will be mounted under the Pilot Screen, and the display unit will be inside the rearview mirror where it will be visible only when lit. The shop wasn't sure the display unit could be installed inside the Gravity mirror, but it turned out to be the easiest to install and conceal they've done so far.
Just as with the PPF shop, this was the first Gravity they've seen, so a lot of what they could pull off was up in the air until they got under the car's skin. They said it's turning out to be a fairly straightforward install so far, with plenty of room to work with wiring, to conceal laser sensors (at least in front), and to mount antennas.
Unlike the Air, which had many liners and covers attached with Velcro, the Gravity mostly uses conventional clips. Also unlike the Air, no bumper has to come off, and the car won't have to go to Lucid Service to have the lidar recalibrated.
They also said the mechanicals and electricals inside the frunk looked surprisingly similar to the Cybertrucks they've worked on.
