Autel Maxi Charger
Bill AGT
Denver, NC
Air GT
CVUA5DWW
Just had the Autel Maxi Charger installed. It works very well - charging at 79 to 80 Amps. It does require an internet connection and will not do wifi. You have to plug in an Ethernet cable or insert a mobile SIM card.
You cannot start without an internet connection. Since this is in the garage and running an Ethernet wire is not an option I tried to get a SIM card. The cost for this was $50 and $30 a month for service.
I finally went with a powerline system where internet goes through the electrical wires in the house. The cost of the two modules is between $30 and $100 depending on the model. This is the model I purchased.
TRENDnet Powerline 1300 AV2 Adapter Kit, Includes 2 x TPL-422E Powerline Ethernet Adapters, IEEE 1905.1 & IEEE 1901, Gigabit Port, Range Up to 300m (984 ft), Simple Installation, White, TPL-422E2K​
This saved me a lot of time and grief so I thought I would share the idea.
