- Nov 27, 2024
- Northern California
- 2025 Lucid Air GT
anyone ever sense this? ..you pull away from a stop or a rolling slow speed and turn the wheel to initiate a turn and feel a small 'tick' or 'knock' as if there's a small amount of play in the steering linkage? When I feel it, if i turn the wheel immediately in the other direction, it doesn't 'tick' back.
In my racing days, I would instantly think that my pitman or idler arm needs to be tightened or a center link bushing is failing, causing a sense of play in the wheel at low speeds under heavy weight shifts of the car. It started a few times, just after the 2.6.16 update, but now it's every time I pull away from a stop and turn the wheel.
I wanted to reach out to y'all before contacting CS, as i'm trying to go an entire month without having to get my car serviced again. ...is anyone else feeling this same thing?
-car drives straight (was just re-aligned a few months ago)
-can not be felt at speeds above 5mph
-have not hit any potholes
-happens in all driving modes
-can not be felt if car is at a stand still (only happens when I accelerate at any speed from a stop)
-i've reset the car several times (i hold the 'a' at least 5 times a week so my sound system works)
thoughts?
thoughts?
