Update 2.6.16
Ampere
Honda Accord Hybrid
Is it my imagination or did the most recent update significantly increase efficiency? In mild weather I generally was getting 3.5 - 4 mi/kwh with my 2023 Touring with 19-inch wheels. With 2.6.16 I'm now regularly getting better than 4 mi/kwh. My driving style hasn't changed and nothing else in the car has changed. (No bricks removed from trunk. <g> )
Also, the lane keep assist is much improved.
The negative side of the update is that the scheduled charging fails. The car starts charging as soon as I plug it in. It never used to do this. I reboot and that works for two or three days and then it once again starts charging immediately.
It seems you are living under a rock hhh jk
They have been talking about .16 update pros and cons for about what 3 weeks
Look it up in the search
I have not had any scheduled charge failures with 2.6.16. But I agree with your other comments. I suggest you contact Lucid about the schedule issue.
I logged in to this topic just to bring up my experience and noticed your post. My AGT *appears* to be getting really high mpKWH since that update. No freeway driving yet, but running around town, up and down hills, 45-50ish mph I was usually getting in the high 3s to low 4s. I'm now hovering close to 5 miles per KWH. In fact the meter even gets up to the max of 6.21 if I go down a few hills. Before my last recharge today, I took a photo of the last 137-mile run between charges and it reads 26kwh consumed with a use of 5.21 miles per KWH. I've NEVER gone that far around here with those kind of numbers. This update seems to have improved things a lot unless there is some trickery with the measurement software. Anyway, I'm happy to see it. Wish I knew what they actually did... perhaps not provide power to the front motor unless a certain pedal force is applied? Any guesses?
Seems only mine is in the other way wagon ☹️ for some reason my mpKWH is low post update. I am below 3 most of the drive where prior it was around 4.1 or 4.2.
