Change to Referral program ? Is it on it's way out ?
Pittsburgher
Pittsburgh PA
93 MB500e 08 BMW528i 6M,
IFPZ58QP
I just went into the referral program and noticed that Air Touring and above now earn only 4000 points (used to be 8000 (Touring) and 10000 (GT)). Did anyone notice when this happened - or if it was communicated in any way ? I had one referral executed (8000 points) and used some - making sure to leave enough so that if I got another 8000 pts. I would be able to get the LHCS. Now I'll have to help Lucid sell 2 more cars to get the LHCS -- they have cut my commission in half ! ! ! I quit. (ha ha). Also looks like some merch is not orderable. Is the whole program going by the wayside ? I know they are not obligated to do so, but if that's the case maybe they should highlight that - might get them a small rush of orders before it's over.
App still shows 4/8/10
Pure was 6 last year, with no announcement changed to 4.
Without the high point Print, 4 across the board makes sense
Wow. Yes there was a change. Its on the referral section of our app and in the Terms and Conditions document that all three types of Air (pure, touring and GT) give out only 4,000 points even though the buyer still gets the $500, $1,000, or $1,250 discount.
It also says all points expire after two years or earlier if Lucid terminates the program. Hmm. Maybe we should use the points sooner than later.
Keep in mind the $0.125 cost per point. If you use more than $600 dollars worth of points or 4,800 points then will send you a 1099.
I'm in the same boat as Pittsburgher. I was set up for enough points to do the factory tour with one more Touring referral. Got the wife on board and everything! With my sights set lower, have they ever offered the carpeted mats in the referral store?
Carpeted mats are currently in the rewards store. Might have to click on the Categories then Vehicle drop-down for them to appear.
All this time I just thought the referral store was limited. Who knew Shop All didn't mean All. Thanks!
