Interesting Results from Recent Road Trip
illopp00
14 CR-V EXL, 24 Air T
Just got back from a day trip. There were some unexpected results.
Conditions: 50 Deg F ambient, mild traffic. 136 mi Total. Average highway speed on ACC was about 70 mph. It is a 2024 Air Touring on 19in with Aero Covers. 2 Adults, 2 kids in the car. HVAC in the front set to 68, rear 70. Used some seat heating and massage for 30 mins of the trip. Smooth mode with High Regen.
Since Last Charge is the full trip which included a little bit of city.
Trip A by habit I normally reset around 88-92 Kwhr to represent a full battery charge.
I thought there was something wrong with the car on the trip there with low efficiency, and then it magically made crazy efficiency on the last leg my wife was driving at about 69 on the highway. There was some traffic that included rolling downhill at about 10 mph for a few minutes. The only other difference was that normally my son likes his HVAC zone on manual so that the fan speed is constant. So 1 zone out of 4 was manual. I changed it back to Auto for all zones.
This is exactly what I get in Florida with 20 inch wheels at 80 degrees weather . Not very close to advertised
It seems you’re implying that Lucid lied. They did not. They quoted the EPA in their advertising and clearly said your results will vary. EPA is achievable when duplicating test conditions.
I find that conversations like this are far easier to evaluate when elevation change enroute is part of the dialogue, and on some occasions head or tailwinds to boot. For example, a lot of uphill on the cold part of the day would look awful relative to the downhill return on the warmer part of the day, and the two do not necessarily offset. Same with head or tailwinds, which can be good or bad in BOTH directions.
I guess what I was getting at was there a significant drop in HVAC consumption between using manual and all zones in automatic? I looked up the elevation change it was about 40 ft.
Ha! It sure wasn't the 40 feet! It's hard for me to believe that the differences in your HVAC usage would account for all that much either. Strange.
I don’t know how you got that from my answer but ok …
net elevation change of 40', correct? but hills in the middle take energy to climb and the regen is less than 100% efficient for the downhills.
Let me ask some awkward questions (not just to Bobby, anyone can chime-in):
> Yes, Lucid was simply quoting EPG numbers, hence they are not lying.
>There is no implied guarantee that you will get the EPA range unless you replicate the exact EPA test condition. Right?
> Isn't EPA testing done on a dynamometer? If YES, was there any wind-resistance effect in EPA rating? Or is it "derated" using a "fudge-factor" to account for the "unknowns"?
> It is well debated in this forum that speed and wind resistance is a BIG part of the efficiency, hence the achievable mi/kWh, correct? If so, how is a scalar "Fudge-Factor" going to account for a quadratic wind resistance effect? In other words, is EPA rating meaningful in any real-life highway driving condition when it comes to efficiency?
> Now, WHO decides on the "Fuge-Factor"? Is it the EPA? Or is it "in conjunction" with the auto manufacturer? Or do the auto manufacturers simply tell EPG what number to plug in?
> If the "Fudge Factor" is determined in conjunction with the auto manufacturer, why are Tesla and Lucid significantly worse when independent tester compare than EPA achievable mi/kWh whilst the Germany manufacturers often met or exceed their mi/kWh rating?
Feel free to correct any mist-statements on my part.
Wouldn't the process be the same for every single vehicle they test? Eg aerodynamics impacts every single car. I would assume they use the tested coefficient of drag for the tested vehicle as that's a known and proven number.
Correct, except it's the EPA.
Correct, because that is how physics works, yes. It is also not guaranteed that the temperature tomorrow will be the same as today or that there will be more or fewer cars on the road or that there will or won't be a power outage. Hell, one of us may not even wake up tomorrow.
The whole point of the EPA testing is to test vehicles under the same set of conditions, providing us with a relative comparison for their efficiencies. It is not and was never intended to be a 'promise' or 'guarantee' of what you'd get under all conditions. That would be an absurd question, given how many factors there are.
It is unfortunate that the EPA offers two methods of testing, a 2-cycle and 5-cycle test, thus muddying their goals of it being a valid relative comparison, but nevertheless, that is not Lucid's fault.
Yes. I have no idea. Yes, it is 'derated' using a 'fudge factor'.
No, it is not well-debated. It is well-understood as fact.
Yes, because it is meant to be a comparison relative to other EVs, in addition to a meaningful estimate for travel. Moreover, plenty of people achieve EPA range, just not in cold weather and driving 85mph+. Drive like the EPA, and you get EPA range.
The EPA applies a 0.7 adjustment factor, effectively reducing the laboratory-tested range by 30%. While 0.7 is the most common, manufacturers can use a different adjustment factor if they believe their vehicle will perform better or worse in real-world driving conditions than the 0.7 factor would suggest. Tesla is an example of a manufacturer that uses a different factor. Lucid does not.
The adjusted city and highway range values are then weighted (55% city, 45% highway) to calculate the combined range displayed on the EPA fuel economy label.
Because, for the sixteen thousandth time, they use the 5-cycle test, and other manufacturers use the 2-cycle test.
That's it. There's no conspiracy. That's the end of it. That's the reason. Believe it or don't, but it is the truth. That is the reason. Please stop asking the same question and seeking a different answer. It is very, very annoying. There is no other answer. This is the answer. This is the correct and only answer. Lucid and Tesla use the more expensive, but better looking, 5-cycle test. The german manufacturers use the 2-cycle test. That is the reason.
In case you missed it, Lucid and Tesla use the more expensive, but better looking, 5-cycle test, so their numbers look better than the German manufacturers, because the German manufacturers don't spend the money on the additional testing. It isn't because the German manufacturers are somehow better people to their customers and are altruistic.
The reason is Lucid and Tesla use the more expensive, but better looking, 5-cycle test. The german manufacturers use the 2-cycle test. That is the reason.
In addition, Tesla adjusts the fudge factor to make theirs look even better. Lucid does not.
(To be clear, the sarcasm in this post is not directed at OP or anyone else in this thread. @BS8899 has been after this EPA range conspiracy for as long as I can remember, which is likely why I have tired of it, and I know I'm not alone. I apologize for my tone, but I'm tired)
Pick a number that will make you happy. I picked 300 miles.
I can go three hundred miles in my Lucid uphill and in freezing weather...I'm good. I don't care if it will do 518 miles.
I don't know if I'd ever want to go 500 miles without stopping. Best I can do is about an hour.
So did yinz figure this out ?
How many angels can dance on the head of a pin ?
I have had my own recent experience on a modestly long road trip. This one was very positive.
I frequently drive LA->SF->LA. I use several different routes, but they don't vary in mileage or average speed by very much. I was pretty unhappy that I could not make the 370 mile trip without a stop, but I knew that my average speed was far from the EPA test conditions. Sometimes I had to make two stops because of the locations of the EA chargers, high or low temps, mountains, etc. My wife was not happy.
I finally found the discipline to run the obvious experiment: slow down and drive in the right lane, keeping my speed in the 68-71mph range for 95% of the drive, speeding only to pass an extra slow vehicle or get out of a bumpy section of my lane.
Voila! I achieved a no-charge trip with 50+ miles or range remaining when I arrived. Of course, I knew well this was possible, but I didn't realize how sharply the range fell off between my normal 78+mph and my new 71mph. (Yeah, I know about I-squared R resistance losses and about V-squared aerodynamic losses, but the delta between these two speed points seems to be much higher than those factors would explain.)
I think software improvements contributed to this success, for which I thank Lucid. In particular, ACC and Drive Assist are both much better these days, so I use them much more. I suspect they also made improvements in my AGT's motor efficiency even before the front-motor improvements announced in the latest software release.
If the EA chargers happened to be better placed, and sized so that I would reliably not have to wait, and paired with a needed bio break, I would likely go back to 78-80MPH. But given the current state of those chargers, I'm pretty happy with my new operating model.
Thanks, Lucid!
Great report, AltadenaAir. I am not at all shocked in the difference in efficiency between 71 and 78.....you're right in the window where things start to get ugly, efficiency wise. The difference between 71 and 78 is so much more pronounced, than, say, 61 to 68. It takes discipline, but if you can stomach sitting in the low 70's, it's a great way to stretch things. I played around with that on a trip where I had driven like a bat out of hell to make it to a college visit. For the way back, the car said we had zero chance of making it to the intended charger (there were closer chargers as an option, but they wouldn't have allowed me to make it home non-stop after that, so I was hoping to make it to the intended charger to make it a one-stop trip). Departing with -40 miles of predicted range, I drove at around 70mph with the hvac off (it was a nice, cool day) and just watched the range climb and climb and climb. By the time it was showing 50 miles left at the intended charger, I picked up the pace and arrived at the charger with around 30 miles left. There's just no getting around physics!
This is why I appreciate their range estimator so much. You can tweak your driving style to make the trip work...it's not always the case that you must drive a certain way all the time. Knowing what levers/knobs you can tweak (range-wise) is a powerful tool and greatly increases the utility of the vehicle...not just for stretching the range, but also knowingly sacrificing range to get everything over with quicker. Case in point, if I'm arriving at a 350kwh charger, I am happy to burn electrons at a higher rate to arrive at the charger faster, and then enjoy the higher charging rates from the low SOC starting point.
@coma24 Yeah, I forgot to mention those optimizations.
I, too, speed up at the end of a trip once I've made it over the mountains and are headed for my reliable home or destination charger. I do the same when heading for a reliable non-EA charge station. Unfortunately, the unreliability and busyness of the EA charge stations prevents me from doing the same with those stations.
And I agree with you, and should have mentioned, that the Lucid range estimator is now reliable enough to use for these tricks. It would be nice to know more about the range estimator algorithm - is it based on my last X miles of driving, or a weighted average over several buckets in a longer time period, or something else? Whatever it is, I find myself constantly doing the mental math of battery remaining x my own estimate of mi/kWhr to get my own estimate of range to inform my driving. But having the car provide a solid estimate is very comforting.
These are great hacks for everyone to try.
