Window not fully closing, tilted
asalotto
2026 Lucid Gravity
Hello! Yesterday I noticed air noise from the driver’s side front window. When home, I noticed the window seemed tilted, so didn’t fully close on the top right corner (looking from outside). I tried several up/downs, tried the full down 3 second hold, tried opening and closing window with door open and closed, tried an overnight sleep cycle. No changes. I noticed this just after 3.6.0, but could be coincidence, although I’ve never had a window issue before.
Any ideas to resolve? Thanks!
If it looks anything like this you should have it fixed asap. Just show it to Lucid and hopefully they can schedule you in. It literally took them < half hour to fix.
Happened while on a trip. I could push it forward and close the door from the outside. It's just some loose hardware in the door and gets progressively worse.
Think it was a production issue that happened to a few cars. If you keep using it ...
Yes, that’s similar to. Mine not as bad yet, but almost. I’ll give them a call. Thanks!
