Will the 756-volt Airs charge slower?
AIR.LUCID
El Dorado Hills, CA
‘04 Prius, ‘98 MB SLK230
Since the 924v Air charges the fasted due to being the highest voltage EV, will the 756v Airs charge slower? I understand the 20% to 80% miles range (260 miles) is different.
This site indicates it will max out at 200kW. I don’t think Lucid has posted an official number.
That site says the useable battery is 88kWh, when 18 modules provide 92 kWh. Why the difference?
The voltage is based on the source side. When you are driving, the source is the battery and it will produce a max of 756 volts. When connected to a fast charger, you will get whatever the fast charger provides. It will be ~900v whether you have a GT or pure.
